ybr 125 - maintenance advice needed
mrr1
PostPosted: 00:01 - 10 Jan 2010    Post subject: ybr 125 - maintenance advice needed Reply with quote
hi all - after binnning my Fazer just before xmas and snapping off pretty much everything that stuck out on the left hand side I've decided to get a cheap winter hack. I've bought a 55 plate YBR125 with 15k on the clock, years MOT & tax for 600 quid off fleabay. Its been dropped a couple of times - a few very light scrapes here and there but nothing that won't fix up nice and shiny with filler, silver spray and some TLC. Engine runs sweetly and rest of bike is straight. I just need to know whats the best oil & plug to pop in and any other advice to help the little thing run as best it can.
cheers
TRX850, TDM900, ST1300, CB650SC Nighthawk, ragtop Saab, gym membership, messy divorce, large chested blonde fiance
Damn, I'm loving my midlife crisis.
miguel_costello
PostPosted: 10:31 - 12 Jan 2010    Post subject: Reply with quote
you can use 10-40w oil. as for the plug maybe check out fleabay again...
Mark65
PostPosted: 20:22 - 12 Jan 2010    Post subject: Reply with quote
CR6HSA is plug, and mine runs better on the 15w40 semi
Mark
neil.
PostPosted: 21:14 - 13 Jan 2010    Post subject: Reply with quote
You might want to do a fork oil change if it hasn't been done already. 10w fork oil is what they specify for it and there's no set interval for changing it, but I was told 20k miles was 'well overdue', so 15k sounds about right. Mark (above) has put heavier oil in his forks and added spacers to increase pre-load on the springs to stiffen the whole lot up, so you may want to do that if you find them a bit too floppy.
As for engine oil, I now use Halfords 10w40 semi-synthetic, no problems. Used to use Shell VSX1 but it was quite expensive. Don't notice any difference with either to be honest. I tend to find after about 2'000 miles, it needs topping up a little bit.
I put a CR6HiX (iridium electrode) plug in for the sake of it. Bike starts first time even in these freezing winter temperatures we're getting now, but was also good with the standard plug. Only a couple quid difference so I thought what the hey... Apparent advantages (so I've been told) are hotter spark, uses less battery power, more efficient burn, a bit more MPG.
If it's the '05 model, check the battery as it ships with the type that needs topping up with distilled water, and people do overlook it, letting the level drop. It may have been replaced with a maintenance free battery by the previous owner, which doesn't need any attention.
Halfords also do a BA20D fitting 35/35w halogen bulb (cylindrical in shape) which is an excellent, considerably brighter replacement for the OEM krypton type (round in shape) in my opinion. It's the only bulb I've tried that doesn't flicker when I'm maxing the speed out on a dual carriageway/motorway. Halogen bulbs I've bought off eBay have been useless and tended to blow quickly. The Halfords one has been in for a good few months now and still going strong.
There's a Haynes manual for the YBR now which is worth getting, and there's also a service manual by Yamaha themselves: https://dl.dropbox.com/u/175946/YBR125ED_3D9-E0.PDF
Parts catalogue: https://dl.dropbox.com/u/175946/Moto-YBR125ED-3D91-2005.pdf
Owner's manual: https://ymenvom.nl/manuals/U3D9E0.PDF
That should keep you busy. Mr. Green Thumbs Up
Bubbs
PostPosted: 22:35 - 13 Jan 2010    Post subject: Reply with quote
neil.martin wrote:
Interesting... where do you actually order the parts?? Need a new side panel as the plastic has broken where it clips on... annoying!
Also have you found any way to make your ybr faster? i notice u have a fly screen. Mine tops out about 58-60 at the moment. Cheers Karma
miguel_costello
PostPosted: 23:46 - 13 Jan 2010    Post subject: Reply with quote
yup, hoon it downhill with the wind behind you Smile
neil.
PostPosted: 08:08 - 14 Jan 2010    Post subject: Reply with quote
I'd say a most official Yamaha dealers would be able to source parts from you just reading out the numbers from that book. I used Woodford Motorcycles in this way, but there's a place nearer to me now in Essex that I'll be trying soon.
I haven't specifically tried to make the bike go faster (a bit like polishing a turd), but the screen helps push the front down when the speed picks up, making things feel more stable. I found it difficult to keep the front end from being a bit wobbly at top speeds before that. I have, on 2 occasions, got 70mph on my GPS and speedo, which, very unusually, seems to be 100% accurate with the GPS. This was on an extremely good road surface, downhill, with the wind behind me and my chin on the tank! Otherwise, I find it tops out at 60-65, with it absolutely screaming at 65 (and taking ages to get there), and I'm not the lightest person (17st). I tend to keep it around 55. Different engine oils/spark plugs haven't seemed to make much difference, and neither has the use of premium fuels, like Shell V-Power (although it has detergents and cleans out the engine, apparently). I'm more interested in keeping it running the best it can, for as long as possible, as it's my only form of transport and I absolutely need it. Thumbs Up
Bubbs
PostPosted: 10:11 - 14 Jan 2010    Post subject: Reply with quote
Yeah me too mate, just thought there was a way of getting the bike to 60-65 without it screaming, mine sounds like its in pain saying "aaaaaaaaaaaaaaaaaaaaaarrrrhhhhggg!!!".
I've read other people's threads who have CG's that 'claim' they reach 70-75 without too much fuss.
Alexio
PostPosted: 10:27 - 14 Jan 2010    Post subject: Reply with quote
My CG has registered 75 on the clocks before without a fuss to get there (70 can be done on flat and 75 once I was on that stupidly big hill) but it definitely sounded like it was trying to commit suicide at 9000RPM Thumbs Up
Also, this is a CG with an engine in absolutely perfect tune and condition. Mine can no longer do it because of thousands of miles of abuse. 65 is about the fastest I ever see on mine anymore.
s1h
PostPosted: 14:20 - 14 Jan 2010    Post subject: Reply with quote
Afternoon, Wheres the best price you have found on the CR6HiX plug?
Mine is having a bit of bother starting in this cold weather and was going to change the plug and came across this forum.
Cheapest I have found for it is about £8. Does that sound about right?
Mark65
PostPosted: 19:58 - 14 Jan 2010    Post subject: Reply with quote
Neil has it pretty much spot on, i changed to 15w fork oil and put 1 extra spacer in and raised the oil height by 10 mm, a lot better for me at 15 stone doesnt nose dive at the slightest sign of the front brake, i also put in a halogen bulb too, try ebay for parts too just type in ybr on the search. Every now and then i run a tank of shell v power through it, but it never lets me down, spark plug is changed at 3000 mile intervals and oil every 1000 miles.
Mark
Mark65
PostPosted: 20:53 - 14 Jan 2010    Post subject: Reply with quote
https://cgi.ebay.co.uk/NGK-IRIDIUM-IX-SPARK-PLUG-CR6HIX-CR6H-IX-Stock-No.-7274_W0QQitemZ360145292217QQcmdZViewItem?rvr_id=&rvr_id=&cguid=2e8c15a21260a0aad284c744fe8ca7e6
mrr1
PostPosted: 19:29 - 16 Jan 2010    Post subject: Reply with quote
great advice chaps!!!
i took the silver flea out for a good spin today after a new air filter, nw iridium plug and a healthy dose of muc-off chain oil. -When i bought her i took the front wheel off and put the whole bike into the back of my car so the first thing i discovered was the speedo cable hub hadn't found the slots on the wheel hub - a bit of a faff to sort but done after 20 minutes. The front caliper was glad of a bit of a strip and clean, rear fender needed refixing. Only things that bother me now are the clutch and the back brake. On my fazer I like the biting point to be about half way between lever fully in and lever fully out, on the ybr the clutch itself won't allow that. The first time i rode it you only had to rest your fingers on the clutch lever and the clutch would be slipping, i assumed the lad who had it before had set it up like that however thats not the case. When I adjusted the cable you simply end up with a clutch cable thats really saggy and a clutch lever that flaps around for half an inch. As for the back brake when you really press on it something clicks and the pedal drops a couple of mill or so. Its more disconcerting than anything - theres that horrible thought that they're about to go pop and fail. Does any of this ring any bells?
Mark65
PostPosted: 20:04 - 16 Jan 2010    Post subject: Reply with quote
I think you can adjust the cable outer with the adjuster under the petrol tank, though i cant gaurantee it, i just use the adjuter at the handle as i prefer it to bite near the end.
Mark
mrr1
PostPosted: 22:15 - 16 Jan 2010    Post subject: Reply with quote
I never noticed that adjustment thing under the tank - just been to have a look at it - how does that work?
neil.
PostPosted: 12:32 - 17 Jan 2010    Post subject: Reply with quote
My back brake has started doing this, it feels as if it's not releasing properly. I am hazarding a guess that it's because the springs that hold the shoes together are worn out and/or the cam is sticking and needs a bit of a clean and a re-grease. For now, I've adjusted the nut on the rod to allow a bit more free play but I really need to sort out new shoes/springs and a give it a bit of TLC around there - it's on my to-do list for my next available Saturday/Sunday, honest!
The adjuster under the petrol tank is for when you have too much free play at the lever due to cable stretching, and can't adjust it there any further. You essentially fully tighten the nut at the lever (which 'resets' it) then turn the adjuster under the tank until you've taken up as much free play as you need. After that you can carry on adjusting it at the lever. I haven't needed to touch the under-tank adjuster yet though.
mrr1
PostPosted: 13:57 - 17 Jan 2010    Post subject: Reply with quote
thanks. Actually my back brake appears to be releasig ok, it does the clicking thing as you're actually braking......
More worrying though is what I've just spotted with the forks. How the hell I missed this when I bought it is beyond me....... The forks are bent back at the wheel about an inch. Its easy to spot when you're stood up by the bars looking down the fork legs. Both sides are bent back by the same amount. - looks like the previous owner has run into a kerb or something. The bike rides straight enough but it still worries me. I can't see any creases / ripples on the frame. How safe is it to ride like this?. Can the forks be straightened? Is this possibly a DIY job or will I need an engineering shop?
Mark65
PostPosted: 10:35 - 18 Jan 2010    Post subject: Reply with quote
They can be straightned as long as theres no creases, i was quoted £25 each when i noticed mine were bent, i had been riding it for at least 6 months like that, i still have my old ones as my bend was only about 4-5mm on each leg measured with a straight edge. As for safe to ride if theres no creses on them and they work smoothly i personaly would think ok maybe, but it depends on where ,how far, and fast i would be riding, nice and easy i would probably use it till i could get it fixed
Lukily my yamaha dealer (Wigan) who i bought the bike off split the cost of the new legs 1 each and sold mine to me at cost, and i got help from lonewolf and colin in the workshop to change them Thumbs Up .
I was thinking of ebaying my old ones as i only noticed the bend when i took the forks out to change the oil weight.
You can get import forks on ebay £85 each, but i dont know if they are the exact same , you would need to check.
https://cgi.ebay.co.uk/Yamaha-YBR125-Left-Hand-FORK-YBR-125-2005-BRAND-new_W0QQitemZ300350734297QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item45ee4c7fd9
The actual fork leg ( the long chrome bit only) on its own is around £100 each from yamaha.
Mark
Bubbs
PostPosted: 11:51 - 18 Jan 2010    Post subject: Reply with quote
Just to go off topic slightly....
I changed my YBR rear brake shoes yesterday (first time ever) and noticed that everything was full of grime and needs a good once over. Now I'm new to all this so don't know what grease to buy etc. Any ideas? The haynes manual was going on about copper grease, and the YBR handbook just says grease.... is there a difference??
neil.
PostPosted: 12:09 - 18 Jan 2010    Post subject: Reply with quote
Copper grease is better at coping with heat and won't melt all over the place, so that's why it tends to get used around brakes. I have also read that it's a good sealant and water resistor, and is specifically meant to stop things seizing. Not sure why Yammy suggest lithium grease. Gonna be sorting mine tonight as the cam is actually starting to seize now (Today, I had to hook my foot under the pedal and pull it up to release the brake shoes)!
Bubbs
PostPosted: 12:30 - 18 Jan 2010    Post subject: Reply with quote
So you reakon just copper grease then for all parts of the bike? Yeah that sounds a bit dodgy mate, did the back wheel lock up?
neil.
PostPosted: 12:49 - 18 Jan 2010    Post subject: Reply with quote
Not all parts, just the backs of brake pads and bits that need greasing on brake parts. It's not good at bearing a load which makes it useless on bearings, where you'd pack lithium grease. The back wheel just 'dragged' along, rather than locking up, but it's not good either way and is pissing me off today as it's on my mind. Thumbs Up
neil.
PostPosted: 22:29 - 18 Jan 2010    Post subject: Reply with quote
Well I just replaced the shoes with a new set - old ones were glazed over but still had a good few mm of wear left. It was rather filthy in there and the cam had completely seized up to the point where it was impossible to actually remove it without the help of a bit of WD40. Springs were still strong, so I basically degreased everything with paraffin apart from the inside of the drum where I used brake cleaner and wiped all the old dust out. Greased the cam and rocker pin, then fitted the new shoes and put it all back together. It's now all very smooth indeed, no clicking, no seizing, no nothing. And this isn't something that's included in the service schedule from Yamaha... Mr. Green
The last post was made 16 years, 257 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 0.51 - MySQL Queries: 16 - Page Size: 132.79 Kb
