dellorto vhst 28 carb
jasepugh1984
PostPosted: 18:17 - 29 Jan 2010    Post subject: dellorto vhst 28 carb Reply with quote
im wondering if anyone would know on the vhst carb that is on an rs125 2007 11kw model,the air mixture screw do you turn it in to make it richer and out to make it leaner.the aprilia settings say 1-3/4 turn but i took it up the road and the plug looks abit lean still.the mixture screw was set with just one turn out before i adjusted it,i was told that my idle problem was caused probably by a lean mixture,so thats why im now adjusting it but unsure which way to turn it to make it richer,thanks.jason
Aprilia Rs125 2007 11kw (SOLD) - Honda CBR600RR 2008 (Current Summer Toy) - Honda Cb600 2000 (Current Work Commuter)
jasepugh1984
PostPosted: 19:00 - 29 Jan 2010    Post subject: idle screw Reply with quote
will number 7 control the amount of fuel going into the carb? and is number seven air/fuel mixture screw.also if number 7 does control the fuel will turning it out let more in?
jasepugh1984
PostPosted: 19:00 - 29 Jan 2010    Post subject: Reply with quote
https://www.apriliagenuineparts.co.uk/component-rs-125-2006-2008-carburettor-ii-692.php
jasepugh1984
PostPosted: 19:02 - 29 Jan 2010    Post subject: Reply with quote
jasepugh1984
PostPosted: 19:04 - 29 Jan 2010    Post subject: Reply with quote
i meant number 6 air/fuel mixture
lonie This post is not being displayed because the poster is banned. Unhide this post / all posts.
jasepugh1984
PostPosted: 19:35 - 29 Jan 2010    Post subject: Reply with quote
so the original settings were it was turn out just one turn would be leaner than if its turned out 1-3/4 turns like aprilia state it should be.
The last post was made 16 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.67 - MySQL Queries: 16 - Page Size: 63.8 Kb
