won't start after jetwash?
PostPosted: 19:57 - 02 Feb 2010    Post subject: won't start after jetwash? Reply with quote
Or deep puddles for that matter.
It can only be getting in via the overflow pipes but there supposed to hang down to the bottom of the bike.
How can i stop it happening?
Thanks
Dave
DRZ-400sm
GSF Jamie 600
PostPosted: 20:11 - 02 Feb 2010    Post subject: Reply with quote
Is it a italian bike? If yes then its to be expected, just clean exposed electricals by hand and only jet tank panels etc
boundy
PostPosted: 20:12 - 02 Feb 2010    Post subject: Reply with quote
You sure its not getting in the plug cap?
PostPosted: 21:07 - 02 Feb 2010    Post subject: Reply with quote
It's a yamaha DT230.Jap import.
The bike back fired a few times before starting up and would then only run at idle.Soon as i give it throttle it died so i'm assuming it's a fueling problem.
DRZ-400sm
Sparks!
Sir Tart-a-lot
PostPosted: 21:11 - 02 Feb 2010    Post subject: Reply with quote
Water getting in the fuel, drain the carb then see if it'll start..
If it does then obviously waters getting in the carb somehow... check the seals etc on the carbs and try to avoid pressure washing the carb area.
PostPosted: 21:25 - 02 Feb 2010    Post subject: Reply with quote
I know it's definately water getting in the carb but it can only be getting in through the overflow pipes.Everywhere else has a nice tight seal.
DRZ-400sm
ben_wheely
PostPosted: 13:00 - 03 Feb 2010    Post subject: Reply with quote
Re-route one of your overflow pipes so that its higher, it lets your carb 'breath'.
Rides: '05 Yammy WR290-F
PostPosted: 00:05 - 04 Feb 2010    Post subject: Reply with quote
Can i extend them above the height of the carb?
DRZ-400sm
yen_powell
PostPosted: 09:56 - 04 Feb 2010    Post subject: Reply with quote
Find the breather pipes that hang down low. Follow them up, cut into them at some high point and put a 'y' piece in, then run a seperate tube somewhere dry and zip tie it in place. 2 strokes seem to like this if doing a lot of splashes and fords. You still get a pipe that drains, but also the engine/carb can still get air when the bottom of the pipe is under the water.
The second thing to look for is the spark plug cap, lead and coil. makes sure it is all in good condition, a slight break or bad connection and even a deep puddle will kill the ignition till it dries out from the engine heat, hence lots of kicking, starter motor spinning.
XT1200Z and a DR350 in bits
PostPosted: 14:38 - 05 Feb 2010    Post subject: Reply with quote
Cheers yen,i'll do that tonight.
It did again today after another jetwash Sad so i drained the float bowl and it started straight up so it's definately not electrical.
DRZ-400sm
Feasty
PostPosted: 15:00 - 05 Feb 2010    Post subject: Reply with quote
I got my bike jetwashed last week and it had identical issues to you, initially started fine but then died a second later till eventually it wouldn't start. It did feel like it was on the verge of starting every time I turned it over but just never quite caught. It was also backfiring every now and again...
I called out breakdown thinking the carb would need flushing or something. However they just removed the spark plug cap, sprayed WD40 all over the spark plug, replaced the cap and hey presto it's not missed a beat since. So try that first if you haven't already done so!
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
PostPosted: 21:42 - 06 Feb 2010    Post subject: Reply with quote
Stripped the carb down today and give it a good clean,checked all the pipes and T'd off the breather pipes and tied them to the frame underneath the tank.
(i did the above because when i got the bike out this morning,petrol pi$$ed out of the overflow soon as i turned the fuel tap on.Could this be related?)
Then removed the HT cap and give it a clean,then sprayed it with this electrical sealant stuff (which i also sprayed all major electrical connections with).
Done all this and it's still cutting out after a wash Confused What else can it be?
DRZ-400sm
alun111
PostPosted: 12:24 - 16 Feb 2010    Post subject: Reply with quote
Why not just refrain from jetwashing the tank/carb area and just do the main bits like the forks, wheels, swingarm?
and
PostPosted: 14:30 - 16 Feb 2010    Post subject: Reply with quote
PostPosted: 17:31 - 16 Feb 2010    Post subject: Reply with quote
ulthar wrote:
Stop jetwashing bikes! Probably does more harm than the dirt!
Mud holds a lot of salt.Salt+aluminum = not good.
The jetwash is really the only way of getting rid of all this:
https://i187.photobucket.com/albums/x13/fronterapics/DTR230%20lanza/Image635.jpg
https://i187.photobucket.com/albums/x13/fronterapics/DTR230%20lanza/Image636.jpg
https://i187.photobucket.com/albums/x13/fronterapics/DTR230%20lanza/Image637.jpg
https://i187.photobucket.com/albums/x13/fronterapics/DTR230%20lanza/Image638.jpg
https://i187.photobucket.com/albums/x13/fronterapics/DTR230%20lanza/Image639.jpg
https://i187.photobucket.com/albums/x13/fronterapics/DTR230%20lanza/Image640.jpg
https://i187.photobucket.com/albums/x13/fronterapics/DTR230%20lanza/Image641.jpg
It's getting better now and i'm starting to think it could be more to do with the spark plug.Definate improvement after cleaning and re-routing carb/breathers.
I like to keep it as clean as i can because underneath all the mud is an immaculate bike and i'd like to keep it as close to that as i can.
DRZ-400sm
and
PostPosted: 18:51 - 16 Feb 2010    Post subject: Reply with quote
PostPosted: 19:00 - 16 Feb 2010    Post subject: Reply with quote
I usually spray the whole bike with wd40 but will give the silicone spray a go Thumbs Up
Either way i really doubt it'll come off with a normal hose pipe,it takes long enough with the jetwash Laughing
The above pics were just from greenlanes.It get's a lot worse than that after a day at the quarry.
DRZ-400sm
and
PostPosted: 19:13 - 16 Feb 2010    Post subject: Reply with quote
PostPosted: 19:31 - 16 Feb 2010    Post subject: Reply with quote
I love getting it covered in mud,but i really hate having to wash it Thumbs Down
I'm riding it off road every other day and the bike is being left a little more dirty all the time.
Be a shame to wreck the bike but at this rate i'm gonna end up not washing it at all and just let it rust Laughing
DRZ-400sm
The last post was made 16 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.84 - MySQL Queries: 16 - Page Size: 106.42 Kb
