exhaust firing flames!
bullet6
PostPosted: 19:46 - 06 Mar 2010    Post subject: exhaust firing flames! Reply with quote
just adjusted the valves on my zx6r b1h,took her for a test ride this afternoon and it was popping a tiny bit more than usual, then when i got in i realised it was shooting flames when giving it some revs at stand still. tbh it looks badass..
but more to the point im worried i buggered something up,is it probably just the carbs needing balancing?
any input would be great
thanks-Rob
bullet6
PostPosted: 19:48 - 06 Mar 2010    Post subject: Reply with quote
also its got a power commander with a custom map...dont know if this would make any difference?..
MaybeGuy
PostPosted: 19:50 - 06 Mar 2010    Post subject: Reply with quote
watch out for that. my GSXR 400 had something similar caused by the output thrust journal throwing out too much fuel.
the engine didnt last much longer after that.
have a check that your chough nut is tight enough, because 9 times out of 10, that solves it before it gets fatal.
bullet6
PostPosted: 21:26 - 06 Mar 2010    Post subject: Reply with quote
thanks for the reply,iv no idea what that is-where do i find said chough nut??? Shocked
MaybeGuy
PostPosted: 21:28 - 06 Mar 2010    Post subject: Reply with quote
its underneath the fuel cap on most bikes. there should be 16 close together bolts, with a central nut in the chough. this is the nut you want.
should be tightened to around 200sqwrls (NOT fltb or NM). may need a special torque wrench for this (try the RSPCA or local park)
make sure you set the cam to 3 before tightening it, otherwise it wont move.
bullet6
PostPosted: 21:42 - 06 Mar 2010    Post subject: Reply with quote
under the fuel cap??man you'v lost me..got a picture?
........hmm does this chough nut have any similarities to a chuff nut? Shocked
mr.kris
PostPosted: 21:44 - 06 Mar 2010    Post subject: Reply with quote
LOL!!!!!! at mat also b1h is injected so it wont be a carb problem
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
MaybeGuy
PostPosted: 22:12 - 06 Mar 2010    Post subject: Reply with quote
they are both fuel injected and carbd. The carbs are backup for the injection in case they fail. Its used for endurance racing.
I mean directly under the fuel cap, remove the tank to see. There should be all the bolts and chough nut i described visible. Its directly under the tank because the fuel iinjection on b1h's is wireless. First model to use it.
Im guessing when you say 'i adjusted my valves' you mean 'i had my valves adjusted for me'
-Savage-
PostPosted: 22:27 - 06 Mar 2010    Post subject: Reply with quote
mattsprattuk wrote:
should be tightened to around 200sqwrls (NOT fltb or NM). may need a special torque wrench for this (try the RSPCA or local park).
I believe that it's called a sciuridae wrench.
https://www.cartoonstock.com/newscartoons/cartoonists/awh/lowres/awhn220l.jpg
bullet6
PostPosted: 22:34 - 06 Mar 2010    Post subject: Reply with quote
ahah well il have another look tomorrow..
no i checked and corrected the clearance myself Rolling Eyes
-Savage-
PostPosted: 23:24 - 06 Mar 2010    Post subject: Reply with quote
Shocked
Noxious89123
PostPosted: 03:04 - 07 Mar 2010    Post subject: Reply with quote
If none of you will put him out of his misery, then I will Laughing
Matt is fucking with you, all of what he posted is a wind up. Rolling Eyes Laughing
I mean srsly... a chough nut? wth Laughing
Ariel Badger
PostPosted: 13:29 - 07 Mar 2010    Post subject: Re: exhaust firing flames! Reply with quote
I may be stating the obvious but you have not adjusted them properly , too little clearance IMHO.
PostPosted: 18:26 - 07 Mar 2010    Post subject: Reply with quote
If it's all adjusted to spec then I wouldn't worry(Just double check it). Is it running a race system?
Also has your PCIII been set up properly?
bullet6
PostPosted: 22:05 - 07 Mar 2010    Post subject: Reply with quote
yeah i realise he was trying to amuse himself-it was a good'un..
took the bike out for another run today,its not backfiring anymore just running rich like its got the wrong map in the pcIII,have'nt had the time to check though but theres no reason why it should have changed.Its running a custom map i had set up last year..
i re-checked the clearances before putting the cam cover back on so they'r good.
The last post was made 16 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 16 - Page Size: 91.74 Kb
