| Grendel |
 Grendel Scooby Slapper
 Posted: 17:03 - 09 Mar 2010 Post subject: My bike is terminal (too expensive to repair) |
Went to get new chain and sprockets fitted today since been putting it off for months. But disaster apparently the front drive shaft is too badly worn to replace the front sprocket and needs replacing but been told it would cost more than the bikes worth to replace the front drive shaft.
Apparently the rear sprocket had also near enough undone itself due to the front sprocket jumping about on the drive shaft and that the suspension is set on the softest setting so very bouncy.
The 2 option he said I had was either keep running it until it dies since it would cost too much to repair of do a temp fix by welding a new front sprocket onto the shaft and stiffening up the Hagon rear shock
I'm completely lost at what to do?
How expensive a job is it?
Is there a cheaper option? ____________________ Past bike: 2004 Hyosung Comet
Current bike: 1993 Honda Transalp
Transalp Page: https://www.facebook.com/home.php?ref=home#!/group.php?gid=11418462079 |
| mad4it028 |
 mad4it028 World Chat Champion
| Pie-Roe |
 Pie-Roe World Chat Champion
 Posted: 17:12 - 09 Mar 2010 Post subject: Re: My bike is terminal (too expensive to repair) |
| Grendel wrote: | Went to get new chain and sprockets fitted today since been putting it off for months. But disaster apparently the front drive shaft is too badly worn to replace the front sprocket and needs replacing but been told it would cost more than the bikes worth to replace the front drive shaft.
Is there a cheaper option? |
Is it worn as in the splines are gone? If so weld a new front sprocket on. You'll get another 5k miles out of it.
Pyro ____________________ Previous: GSF600, FZR600 x2, ZXR750, XT600 Tenere, CB125, CZ125, ETZ 250, ER5, CCM R30, DRZ400, RF600x4, RF900x2, GS500, VTR1000F, 640 SMC, CB250 NIGHTHAWK, GT550x3, GPX750 TE610, CB500, X11x2, SV650, ZING 125, TL1000R,CB250 Superdream, CBR1100XX |
| Kickstart |
 Kickstart The Oracle
 Posted: 17:14 - 09 Mar 2010 Post subject: |
I would be surprised if it is that worn without there being other symptoms, and I can't see the rear sprocket coming unbolted just due to the front sprocket moving (the chain will absorb the movement).
Can you take off the front sprocket cover and take a piccy?
As to the shock, how stiff that should be will depend on your weight, etc. Adjusting it should be a simple job.
| Grendel |
 Posted: 17:36 - 09 Mar 2010 Post subject: |
Yep apparently the splines have got too worn down.
someone on another forum has mentioned using chemical metal?
Since i'm fairly mechanically inept.
As for the rear shock it's a fairly new Hagon mono-shock which to ajust you need to take off apparently? ____________________ Past bike: 2004 Hyosung Comet
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 17:41 - 09 Mar 2010 Post subject: |
why cant you weld up the splines and file them down again? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Robby |
 Robby Dirty Old Man
| Grendel |
| Paddy Blake |
 Paddy Blake World Chat Champion
| Grendel |
| MaybeGuy |
| Paddy Blake |
| MaybeGuy |
 Posted: 18:12 - 09 Mar 2010 Post subject: |
DIY. a welder costs less than that. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Grendel |
 Posted: 18:33 - 09 Mar 2010 Post subject: |
True except i have no idea how to use a welder.
But i do have a friend who may. But i think its a Arc welder he has. Would that still be strong enough weld? ____________________ Past bike: 2004 Hyosung Comet
| Blau Zedong |
 Blau Zedong Banned
| Frost |
 Frost World Chat Champion
 Posted: 19:00 - 09 Mar 2010 Post subject: |
I had a bike that was worth £5-600 when a gear went inside the box. Local garage quoted me £1100 to fix it. Probably total bollocks, they just didn't want the job. Bought the gears for it for £110 and fixed it myself in a few hours.
A bike a garage says isn't worth it, isn't worth it for them. Provided the cost of fixing is less that the cost of a replacement bike i'd say do it yourself. At very least get it all appart and see what you think before buying parts. At the very least you'll learn something  |
| MaybeGuy |
| Kickstart |
| c_dug |
 c_dug Super Spammer
| evoboy |
 evoboy World Chat Champion
 Posted: 19:35 - 09 Mar 2010 Post subject: |
| MaybeGuy |
 Posted: 19:37 - 09 Mar 2010 Post subject: |
i misread. i thought you meant if the splines were repaired. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Pete. |
 Pete. Super Spammer
 Posted: 20:18 - 09 Mar 2010 Post subject: |
As Kickstart said, can we have a photo of the shaft?
A quick squirt with the mig isn't going to melt the output shaft seal. Welding on a sprocket is a mighty bodge but it need not be done just the once. It would be possible to change the sprocket by grinding back the weld. The temper of the shaft would be affected by the welding though and if the splines are completely gone the weld would be carrying the whole load of the engine.
Building up the splines with weld and filing to shape isn't that much of a bad idea, but would be a lot of work and of course the new spline tops would not be hardened. Keeping the shaft greased would help reduce wear. ____________________ a.k.a 'Geri'
| Grendel |
| Grendel |
| Paddy Blake |
The last post was made 16 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
