Quick VB Question
crazymotorbik...
PostPosted: 01:04 - 25 Mar 2010    Post subject: Quick VB Question Reply with quote
Hey,
Just a quick VB6 Question....
When closing a form using the x button how do you catch this?
I'm guessing its fairly straight forward. I used to know but haven't touched VB in many years.
Cheers,
Shaun.
PostPosted: 01:20 - 25 Mar 2010    Post subject: Reply with quote
Not touched VB6 in 2.5 years, but a quick look and I found this:-
https://episteme.arstechnica.com/eve/forums/a/tpc/f/6330927813/m/8030963785
Frost
PostPosted: 02:09 - 25 Mar 2010    Post subject: Reply with quote
My bet would be:
Double click on the top of the drawing window, in the bit you'd normally drag a window about by. The code editor should then pop up, in the top right hand side there will be different event's pick the window close one and slap the code in that function.
Alexio
PostPosted: 03:37 - 25 Mar 2010    Post subject: Reply with quote
It's one of the events listed for the window object. So, double click anywhere on the window. You will automatically go to the Load event, so instead select the Exit event (or what ever it's called) at the top right of the code window from what I can remember.
Ah, I miss VB6.
PostPosted: 11:46 - 25 Mar 2010    Post subject: Reply with quote
Alexio wrote:
Ah, I miss VB6.
Same here. Far preferred it to the .NET rubbish.
crazymotorbik...
PostPosted: 22:41 - 26 Mar 2010    Post subject: Reply with quote
Hey,
Thanks very much Smile
Karma all round.
Must admit i do enjoy VB!
Cheers,
Shaun
Frost
PostPosted: 01:08 - 27 Mar 2010    Post subject: Reply with quote
If you enjoy VB, look into C# its basically the same but alot more powerful and portable.
Alexio
PostPosted: 02:38 - 27 Mar 2010    Post subject: Reply with quote
The original VB is nothing like C#.
PostPosted: 12:33 - 27 Mar 2010    Post subject: Reply with quote
Very true. VB6 is useful and doesn't try and hide things in half useful libraries all over the place.
Alexio
PostPosted: 20:09 - 27 Mar 2010    Post subject: Reply with quote
Laughing Haha, this is the second time I've heard you mention this recently.
It's one of the reasons why I'm addicted to PHP rather than ever use the .NET libraries. Because you are required to create every single last thing yourself that comes out to the web browser you get to do every last thing right and perfectly. When creating your own libraries (which of course you end up doing and is an invaluable skill to develop) you do them exactly how you need so it's a language that while slower (at first) becomes 100% useful to you.
PostPosted: 20:43 - 27 Mar 2010    Post subject: Reply with quote
I am the same. I like php. I would prefer it if it had variable types and declares, and also if you could easily play around with pointers (although gets bad when you get it wrong). Also it can be a bit inconsistent with the orders of parameters to functions.
I am not that keen on object orientated programming. I think it has a place when you have a reasonably size distinct object, but treating strings (for example) as objects is just silly. Written a few I use, to draw graphs and another to draw pie charts.
I do quite like mixing php and Javascript.
That said, I wish I could easily run Javascript on the server and call it from php. I have a Javascript function at the moment that I also need to run on the server, and having 2 versions needing maintaining in different languages is asking for trouble (OK, I could use Ajax, but this function is potentially called for every cell of a very large table, so potentially thousands of Ajax calls when a page is refreshed).
Alexio
PostPosted: 21:02 - 27 Mar 2010    Post subject: Reply with quote
Is the JavaScript and PHP code for validation? If it is, what I would do is create a kind of parsing engine so that you store the commands of how to validate the data in the database, and your engine spits out JavaScript / executes PHP based on what comes out.
Can be complicated but then you end up maintaining the code in the same place because both sets of code are generated from the same data.
PostPosted: 21:18 - 27 Mar 2010    Post subject: Reply with quote
The db stores strings which say how an element is validated (ie, multiple validation strings for an element). The page has a list of items vertically and a list of tests horizontally, with each resulting cell having a value. Each value is then checked against the validation strings for that test.
The javascript just compares the values with each validation string until it gets a match.
It's horrible enough to read without trying to generate code to evaluate.
The last post was made 16 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.65 - MySQL Queries: 16 - Page Size: 84.96 Kb
