ZZR valves... Kickstart/stinkwheel please look :)
djr
PostPosted: 19:06 - 27 Mar 2010    Post subject: ZZR valves... Kickstart/stinkwheel please look :) Reply with quote
Right... Back... Before Christmas I think (I'm a little bit lazy as the misses keeps telling me!) i took the z apart as it had broken down and wouldn't start anymore, it had done this the previous time i rode it but after changing the spark plugs it ran fine (besides having no power below 4000 rpm) couple of mates suggested to check the valves and that it was a common problem on krapasakis Sad.
Anyway fairings off, valve cover off, measure up all the valve gaps. Cam shafts off(under bucket shims... What fun!), measured each shim. After ordering new shims and fitting them the fun starts... First camshaft in, lined up. Second one in lined up and the chain was really loose between the two sprockets and the first (exhaust) sprocket was nolonger in the right place.
Anyone any expirience with these bikes and have any suggestions on how to make it easier? Have read lots on the internet of people taking over 7 hours to do the valves on these but can't find any tips on how to get them back in.
After about 5 attempts i'm quite tempted just to throw it on ebay OR put in back of a van and take to a dealer and see if they'll put them back in for me Neutral.
PostPosted: 19:11 - 27 Mar 2010    Post subject: Reply with quote
Never done them on the ZZR, but Yamahas need the cams out quite often as well. Often you land up one tooth out, so just take that cam out and move it a tooth round. Can take a few attempts.
djr
PostPosted: 19:16 - 27 Mar 2010    Post subject: Reply with quote
THere's not all that much space to play in round there though - been trying that but it's a right pain in the bum as you have to get the chain round the second sproket before connecting it to the other sproket (is it normal or just a "krapasaki" thing to have the two sprokets together Sad ? only video i could find of someone doing it on youtube was on a klr but those sprokets weren't together Sad.
Frost
PostPosted: 19:23 - 27 Mar 2010    Post subject: Reply with quote
Yes two cogs together is normal. You have removed the chain tensioner haven't you? Be pretty funny if you hadn't Laughing
It's definatly worth fitting a new cam chain if your fiddling with it anyway. If you are doing so, check it's the same length as the original.
djr
PostPosted: 19:30 - 27 Mar 2010    Post subject: Reply with quote
think is... Surely unless you take the whole thing apart you can't check the lengh of it? (cause i was under the impression that way you fitted it was to break the old one, join the new one to it, turn the engine over untill the new ones all the way round then break the old one off and join the two new ends together? (hope that makes sense :$.).
Frost
PostPosted: 19:39 - 27 Mar 2010    Post subject: Reply with quote
Yup thats the way to do it. So Turn it over with both attached until the join is at the bottom, then make sure you have the same length of either coming out the top. You can also re thread the chain by using gravity to get it down, then a bit of string to get it back up Wink
Normally you have no excess length to play with, but with the tensioner out you have the exact right length to hook it on the sprocket and join them up. Sounds like you might have too little chain, or maybe something isn't seated correctly? Perhaps the cam's are at TDC but the engine isn't?
djr
PostPosted: 20:10 - 27 Mar 2010    Post subject: Reply with quote
Right... WHen the T1.4 bit lines up with the mark down the bottom is this Always TDC or will this be the case for BDC aswell? (also - At BDC will any of the cams be in contact with the buckets or will they all be pointing away then aswell?)
Frost
PostPosted: 20:26 - 27 Mar 2010    Post subject: Reply with quote
The mark will only line up at TDC. At TDC 2 pistons will be up, 2 down and all valves closed. Any other position and the cams won't sit right.
lonner
PostPosted: 20:46 - 27 Mar 2010    Post subject: Reply with quote
krapasaki you say Laughing
more a case of fuckwit owner
there easy and a monkey can do it go figure Thumbs Up
and yes you can take that as an insult Very Happy
PostPosted: 20:48 - 27 Mar 2010    Post subject: Reply with quote
TDC on 2 cylinders will be BDC on the other 2 on an inline 4 (well, not on a current R1). On bike engines with wasted spark ignition then it doesn't matter which TDC cylinder 1 is on (unlike a car with a distributor).
Problem is that if you hook the cam sprockets into the cam chain and then push the cams down into place they will slightly rotate in relation to the head.
djr
PostPosted: 20:51 - 27 Mar 2010    Post subject: Reply with quote
Name a good kawasaki then? I think most of the water cooled ones have a history of head gaskets. I believe a number of them have problems with Reg/Rec's failing...
And 3 and a bit thousand miles between checking shimms is a bit of a piss take. I'm sure that's what HAynes quotes any way...
djr
PostPosted: 20:59 - 27 Mar 2010    Post subject: Reply with quote
Hi Keith - but once the two sprockets are together I can't get the chain around it (and i can't even get my hands or anything round the bottom of the sprocket so can't even help it on from the bottom.) Any ideas or am i missing something Embarassed.
Frost
PostPosted: 13:27 - 28 Mar 2010    Post subject: Reply with quote
Get it so that the chain is in place on the bottom cog with it in TDC. Have equal amounts of chain hanging over each side of the head. Find the way the cams go and place them on top of the head, then wrap the chain over.
The last post was made 16 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.19 - MySQL Queries: 16 - Page Size: 84.44 Kb
