12v Plug Socket: Stinkwheel?
PostPosted: 19:49 - 30 Mar 2010    Post subject: 12v Plug Socket: Stinkwheel? Reply with quote
Do I need a relay?
I realise that if I don't and leave something plugged into it my battery will drain, but as long as I only plug things in when the engine is running, is there any need?
Ideally I just want to run two wires to the socket with a switch and fuse in-line but I'm guessing the switch could burn out from the power thus me needing a relay.
Another option is to just run two wires to the socket with an in-line fuse. Would a 13amp fuse be good enough?
Karma
Blue_SV650S
PostPosted: 19:52 - 30 Mar 2010    Post subject: Reply with quote
Bearing in mind the low current things that are normally plugged into lighter sockets, You don't even need a relay if you had it on a switched live ...
So, the simple answer is no!! Wink
PostPosted: 19:56 - 30 Mar 2010    Post subject: Reply with quote
Super. Only thing I'll be plugging into it is a PDA and GPS receiver and occasionally a AA battery charger.
carvell
Scuttler
PostPosted: 20:00 - 30 Mar 2010    Post subject: Reply with quote
No, you don't need a relay.
A fuse and two wires straight to the battery is fine. You only need a relay if you want to switch a high current with a low (ish) one.
Yamaha TDM 850
PostPosted: 20:04 - 30 Mar 2010    Post subject: Reply with quote
What fuse should I be using?
Blue_SV650S
PostPosted: 20:06 - 30 Mar 2010    Post subject: Reply with quote
7.5A is more than enough, the lower the A the better ... nothing you will be plugging in will be >1A to be honest!! Wink
PostPosted: 20:09 - 30 Mar 2010    Post subject: Reply with quote
I've got 5amp fuse so I'll use that.
Cheers people.
carvell
Scuttler
Yeah indeed.
Pretty much anything you've got knocking about would do. 10A would probably be the most ideal, but if you have only got a 13A or have only got a 5A then they're fine.
If you're buying one especially though I'd probably get a 10A.
Yamaha TDM 850
PostPosted: 21:00 - 30 Mar 2010    Post subject: Reply with quote
Inline 5amp in mine. Directly to terminals. No problems when not being used.
Got mine from Maplin for <£4
Pat
PostPosted: 21:34 - 30 Mar 2010    Post subject: Reply with quote
Pat
I got mine out of the bottom of my toolbox Laughing Found an in-line fuse holder as well and I already had a 5amp fuse so it's cost me a total of £0 Cool
My kind of mod.
PostPosted: 23:30 - 30 Mar 2010    Post subject: Reply with quote
Just don't come crying to me if you leave something plugged in and flatten your battery.
PostPosted: 01:03 - 31 Mar 2010    Post subject: Reply with quote
I won't because it's kickstart anyway Wink
CptBlack
PostPosted: 02:03 - 31 Mar 2010    Post subject: Reply with quote
I bought one of these a few months ago link although it was cheaper then - shop around
PostPosted: 17:01 - 31 Mar 2010    Post subject: Reply with quote
Fitted and working.
Mocked it up and checked I could still close my seat:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1791.jpg
Then found a bracket which I cut, twisted, bent and attached to the socket using a jubilee clip:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1793.jpg
That doubled up as the earth.
Found a ring terminal in my toolbox and crimped that on to the wire and attached it to the battery with the 5amp fuse in-line.
My PDA on charge:
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1796.jpg
https://i15.photobucket.com/albums/a376/ms51ves3/DSCF1801.jpg
Even with the PDA on charge the PV still cycles when the ignition is turned on Thumbs Up
A job well done Mr. Green
The last post was made 16 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.04 - MySQL Queries: 16 - Page Size: 85.79 Kb
