| Alexio |
 Alexio World Chat Champion
 Posted: 18:01 - 08 Apr 2010 Post subject: My CG is not happy! |
So, for the last three days now, every time I have started my engine from cold I've been forced to bump start it. It's as if my battery is very low, allowing my starter motor to spin my engine about twice before grinding to a halt. If the engine is warm then there's only just enough juice left in there to get it going and then it's fine.
However, my CG has been on journeys recently which ought to have been long enough to have my battery in tip top condition. So while I haven't yet checked the levels in my battery (it's pretty new anyway) I now have to assume that my alternator is failing me.
Further evidence to suggest this is that when ever my engine produces a certain amount of vibration (meaning various bands of revs) a noise which is basically metal scraping against metal comes from below me. I'm assuming this means it's pretty much going to be FUBAR inside... although seeming as my bike is still working it is hopefully still producing at least a small voltage which allows my spark plugs to soldier on.
So bea sea ef, what do I do? Is it easy to open up the cover and take a look? Is this something that is likely to have started failing after 23,000 miles or so? And how much will it cost?  ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| N cee thirty |
 N cee thirty Banned
| vcrmoss |
 vcrmoss Two Stroke Sniffer
| Alexio |
| 27cows |
 27cows World Chat Champion
| Alexio |
 Posted: 11:33 - 09 Apr 2010 Post subject: |
Well, after consulting my local garage for a free 60 seconds of advice the mechanic noticed that when you revved my engine my headlight actually started to dim
I assume that's because the spark plugs are not only pulling power from the ignition coil / part of the engine still generating electricity but also any life left in my battery. I have now realised that ideally I should charge my battery up immediately before I ruin it. Although, it does seem to be charging incredibly slowly.
*Sigh*. I'll have to try and find some time to have it all apart. Thanks for the advice. Google is being useless in helping me find prices for parts. ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
| virus |
 virus World Chat Champion
 Posted: 11:40 - 09 Apr 2010 Post subject: |
Get the official flywheel puller from david silvers, its only about 8 quid and well worth it.
I spent 3 days and lost about a pint of blood trying to use 3 wheel pullers, long screwdrivers and hammers removing the flywheel on mine before I relented and got the honda tool, screwed it in, gave it a light tap with a small hammer and the flywheel came right off.
Cheers
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| N cee thirty |
 N cee thirty Banned
| Alexio |
| 27cows |
| Alexio |
| P.addy |
 P.addy Red Rocket
| Robby |
 Robby Dirty Old Man
 Posted: 16:02 - 09 Apr 2010 Post subject: |
Before you go crazy pulling the engine apart, have you considered that you could just have a knackered battery?
When a battery is old it loses its capacity to store a charge, so in effect your 10Ah battery is now a 1Ah battery. If the battery is more than 5 years old, or has been neglected in the past, it probably needs replacing.
The ignition system draws a tiny amount of power.
It is also possible that the reg/rec is dying, it's a classic Honda fault and there should be a method of testing it with a multimeter in the haynes manual.
I think a CG also has a ballast resistor that does something to do with the lighting, sitting beneath the headlight on the yokes. Memory is hazy, but I think it rusts where it connects to the yokes and knackers the resistor.
Charging test first. Connect a multimeter across the battery set to read volts. Before starting the bike, with the ignition and everything else off, a healthy battery will read about 12.5 volts. 11 or below is bad.
Now with the engine running on tickover you want to see at least 12 volts, and it should be higher than with the engine off. Turn the headlight on, and see if you get a significant voltage drop.
Now, headlight off. Rev the engine to between 4000 and 5000 rpm and hold it there until the reading settles. You should see around 14v. If it is more like 30-60v, your reg/rec is knackered. If it is the same or less than with the engine off (12v or under) then it isn't charging. This could mean a reg/rec failure, a broken wire on the charging circuit, or a failed stator.
Again, there should be stator tests in the haynes. If it runs the stator as two difference circuits then I would assume that you can test the resistance across each circuit and see if they are wildly different. |
| 27cows |
| Alexio |
 Posted: 16:54 - 09 Apr 2010 Post subject: |
Sadly cows I think something is adrift inside of my engine as you suggest. Anyway, massive thank you Robby, I shall be testing my electrics and looking for corrosion before pulling the engine apart.
And Paddy, I know I've been mentioning it for months now but if you want to come down here and help me pull my engine apart near the end of the month that would be much appriciated  ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
| N cee thirty |
 N cee thirty Banned
| Alexio |
| N cee thirty |
 N cee thirty Banned
 Posted: 18:18 - 09 Apr 2010 Post subject: |
| 27cows |
| Alexio |
| 27cows |
The last post was made 16 years, 120 days ago. Instead of replying here, would creating a new thread be more useful? |
