manu L Plate Warrior
bikedudextrm Traffic Copper
Posted: 12:48 - 10 Jul 2004 Post subject: |
The bike full power should manage 50mph easy. On Piaggio's 50's there's a washer in the variator (a small black plastic/nylon washer). Its on the front pulley assemble (on the left) inside the kick start case, the washer is between the variator and the belt. There should also be a small pipe coming off near the top of the exhaust (you should be able to see it) which is blanked off, this will require cutting off and the hole left welded up. ____________________
https://www.bikepics.com/members/bikedudextrm/ |
