Sky + self setup
Mr.Everready
PostPosted: 14:24 - 11 May 2010    Post subject: Sky + self setup Reply with quote
I've currently got Sky+ along with a normal box on multiroom. They are currently offering the HD box free for self setup ( £10pm ). I was going to move the + box into the other room but it currently has only one input cable.
The dish has a quad lnb, how easy is it to wire up the lnb yourself with the fourth cable ?
Mr.Everready
PostPosted: 14:30 - 11 May 2010    Post subject: Reply with quote
PS, I assume this will work without telling Sky ? I can't be arsed with the engineer coming round asking where the phone socket is. Laughing
Davo
Davo To The Rescue!
PostPosted: 14:41 - 11 May 2010    Post subject: Reply with quote
You only need two inputs for the recording functionality of SKY+ (you can switch the Sky+ boxes on to single LNB mode, if you don't want recording functionality)
Installation wise, as long as you can get access to the dish, it's just literally a case of running the cable down from the dish & connecting up both ends.
Although I'd be tempted to replace the single cable with a double barrelled shotgun style (like below), which is what most Sky engineers will do.
https://www.tlc-direct.co.uk/Products/CAPF2100B.html
After the cable's been run in, you will just need to crimp on a couple of F-type connectors (as below)
https://www.tlc-direct.co.uk/Products/MX097R.html
Mr.Everready
PostPosted: 15:07 - 11 May 2010    Post subject: Reply with quote
Aye, I could use the + box as standard but might as well double it up, I live in a cottage so the lnb is at eye level so no problems there. I did see the shotgun cables on ebay here
Davo
Davo To The Rescue!
PostPosted: 15:32 - 11 May 2010    Post subject: Reply with quote
Sounds like that should work, apparently WF100 is better, but WF65 will do the job (Assuming 20m is enough).
The last post was made 16 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.71 - MySQL Queries: 16 - Page Size: 46.57 Kb
