BASIC ELECTRICAL PROBLEM (ccm604 ignition switch)
stirlinggaz
PostPosted: 19:20 - 12 May 2010    Post subject: BASIC ELECTRICAL PROBLEM (ccm604 ignition switch) Reply with quote
hi all,
i just picked up a ccm604, the sm version.
someone had attempted to steal it but was caught in the act,lol
anyway, it came with the keys etc & is all legit.
but basically, when i turn the key nothing happens.
i have put a freshly charged battery in but the would-be thief has attempted to hot wire it.
on the back of the actual ignition barrel, there are 4 (conveniently numbered 1 to 4) prongs, onto which 4 wires slot on, by means of crimp terminals.
problem is, i dont know which wires go where!
the wires are YELLOW
BLACK/with white tracer
BLACK
BLACK
the wire with the white tracer, i touched the red probe of my multi-meter to & the black probe to earth & i got 13v.
thats as far as i got, before i start randomly connecvting wires,
any ideas on how to wire it properly?
or by pass the switch alltogether?
i know, this is, in effect,asking how to hotwire a bike, so please feel free to PM me,
cheers,
GAZ
finpos
PostPosted: 19:45 - 12 May 2010    Post subject: Reply with quote
Wiring diagram often helps, but if you don't mind living dangerously and perhaps exploding something (hopefully just a fuse) -
1) With nothing connected to anything else, try start the bike (kickstart?)
2) If you need power to start the bike, try and find a dead short between one of your remaining 3 spare wires and either one of the two terminals on the brake light switch (I'd suspect the yellow wire). Then connect your live (black/white) wire to that wire. See if any of the lights etc. work, if they do try to start the bike.
f.
stirlinggaz
PostPosted: 13:12 - 13 May 2010    Post subject: Reply with quote
hi,
i dont really understand what you mean,sorry!
it needs power to start, by kick-start as well as electric starter.
connect my live wire to what?
cheers,
GAZ
stirlinggaz
PostPosted: 14:31 - 13 May 2010    Post subject: Reply with quote
I got lucky, first 2 wires that i touched together & it powered up!
no wonder bikes are so easily stolen,lol
stilson grip to remove the collar & pull out the full ignition switch & join 2 wires together & the bike powers up.ffs.
next problem, find out where the 4 wires are supposed to go!
oh, & find out why the starter solenoid is just buzzing loudly.
cheers,
GAZ
steveh
PostPosted: 19:11 - 13 May 2010    Post subject: Reply with quote
cheers,
GAZ
solenoids "buzzing" is usualy a sign of a low battery?
steve.
stirlinggaz
PostPosted: 11:24 - 14 May 2010    Post subject: Reply with quote
steve.
yup, bike didnt have a battery fitted, so i tried an old 10amp thing from my vfr700,forgetting that it hadnt been used for a while.
a couple of hours on the trickle charger & the bike started 3rd or 4th press of the starter button. Very Happy not bad for a bike thats been sitting unused for 4 or 5 years.
think i got a result, seing as theres only 700km's on the clocks, 1 previous owner & its been dry stored, so shouldnt take much to get it ready for mot.
sounds good with the remus can, though a bit loud for my taste,lol
now just need to find out what type/size of battery it SHOULD take, as this one is physically too big.
i can figure out how to wire in the ignition switch later.
cheers,
GAZ
mad4it028
PostPosted: 12:11 - 14 May 2010    Post subject: Reply with quote
as standard it same battery as a zx6r ctx9-bs but if i remember rightly the busa battery fits and gives alot better cranking power the standard battery is killed if it dosnt start right up and is a pain
also make sure you cover all electrics with wd40 regualy as they dont like the wet
The last post was made 16 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.26 - MySQL Queries: 16 - Page Size: 56.33 Kb
