CANT DO THIS ALONE ANY MORE GOT BUSA ISSUES NEED HELP
505fatboy
PostPosted: 03:07 - 13 May 2010    Post subject: CANT DO THIS ALONE ANY MORE GOT BUSA ISSUES NEED HELP Reply with quote
i am new to this chat thing but i figured that a bunch of ideas and suggestions from people like myself who do their own bike work is the way to go! I got two issues with my Hayabusa the first is rear suspension problem I am "bottoming out" or something, I have recently dropped and streched my swing arm and though the ride solo is fine a passenger is definitely out of the question! Any suggestions? 2-- I also have had a " surge" or a rpm jump only in 1st gear and only at 30 mph of 3000rmp which ever comes first and like I said only in first gear! PLEASE HELP
temeluchus
PostPosted: 07:03 - 13 May 2010    Post subject: Reply with quote
A longer swingarm means it has more mechanical advantage over your shock absorber. You will, at least, need to fit a heavier spring to the shock.
By "surge" do you mean the bike hesitates/stutters?
Apparently earlier ones had slightly fluffy fuelling low down at slow speeds-Id imagine a engine tuners could sort it or invest in a power commander or similar to cure it.
Pete.
PostPosted: 18:59 - 13 May 2010    Post subject: Reply with quote
You're going to have to re-spring the shock if you're bottoming out. The swingarm brace hits the bottom of the battery box.
As far as the fuelling goes - check your TPS. Find the dealermode connector in the left side of the seat unit, it's a 4-connector block with just 2 wires going to it and a rubber cap. Join those 2 wires with a paperclip and start the engine. On your LCD readout you'll have a line, that should be in the middle on tickover and jumps up when you rev the bike. Set the TPS so it jumps up to the top at 1750rpm.
a.k.a 'Geri'
The last post was made 16 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 16 - Page Size: 38.03 Kb
