Clutch not working.
Misc
PostPosted: 16:27 - 14 May 2010    Post subject: Clutch not working. Reply with quote
I had a leak of oil somewhere on my '96 Bandit behind the sprocket cover. I then remove the cover & found the oil was coming from the metal rod as shown in photo. I then found that the hole the rod goes into (the shaft with tiny ball bearings) was missing a bearing, it was lying on top of the cover so i remove it, cleaned it, greased it & put all the bearings in the correct hole in the shaft. I put everything back together & left it for the night. Went to go out on it this morning & stuck it in first gear, let out the clutch & nothing happened.
The bike doesn't stall with the clutch fully out. I thought this was down to the alignment bolt & nut so i adjusted this in so many ways but it's the same. When out of neutral, you can start the bike in any gear by holding in the clutch, so the clutch is working but i think i may of missed something out.
Any thoughts? Am i missing a part? I've tried searching for manuals showing how it's put together but the diagrams are never for this exact bike. Usually a US model which has different parts. Like This site.
Thanks.
https://img532.imageshack.us/img532/2710/dsc00186o.jpg
https://img130.imageshack.us/img130/2813/dsc00187og.jpg
Oil leak below.
https://img697.imageshack.us/img697/2801/dsc00189g.jpg
https://img295.imageshack.us/img295/4897/dsc00188e.jpg
https://img38.imageshack.us/img38/4025/dsc00185et.jpg
Ball bearings inside shaft reassembled.
https://img38.imageshack.us/img38/4164/dsc00191yy.jpg
https://img293.imageshack.us/img293/2019/dsc00190tp.jpg
PostPosted: 16:34 - 14 May 2010    Post subject: Reply with quote
Can't remember if or where the ball bearing goes in the 600 Bandit clutch.
However if you have effectively changed the length of the clutch pushrod then you need to adjust it. That is the adjuster that is on the sprocket cover. From memory, slacken off the lock nut, back off the adjuster quite a way and then tighten it until it just makes contact (so you just start to feel resistance), then back off half a turn and tighten the lock nut.
Suspect what is happening at the moment is that the push rod is being pushed by the adjuster so it it holding the clutch released whatever you do with the cable. The switch to allow the bike to be started with the clutch pulled is on the clutch lever I think.
Misc
PostPosted: 16:49 - 14 May 2010    Post subject: Reply with quote
Kickstart you're a star! Mr. Green I've been trying the same thing all morning in different positions but did what you said & not it seems to be working correctly. Just need to set it up properly.
Appreciated.
By the way am i missing a rubber washer? Want to stop that leaking from the hole the rod sits in.
Karma
PostPosted: 20:54 - 14 May 2010    Post subject: Reply with quote
There should be a seal there, and from those pics it looks like there is one. Could just be damaged.
Misc
PostPosted: 21:09 - 14 May 2010    Post subject: Reply with quote
Thank you. Will order a new one to be sure.
Misc
PostPosted: 21:02 - 16 May 2010    Post subject: Reply with quote
I forgot to ask, when replacing the washer is it best to drain all the oil from the bike (Changing it soon anyway) or will only a small amount come out once i've removed the existing washer?
SW Motech Shop UK
PostPosted: 21:46 - 16 May 2010    Post subject: Reply with quote
If you haven't done it already take the drive gear out and clean it, then grease and refit. Bandits collect a load of crap inside the sprocket cover and it collects inside the worm drive. It will work much better if you do this.
https://www.motorcycle-road-and-race.co.uk and https://www.sw-motech-shop.co.uk/ and https://www.motorcycle-luggage.co.uk/
PostPosted: 22:04 - 16 May 2010    Post subject: Reply with quote
Not much will come out. Even less if you lean the bike against a wall with some padding behind to stop it getting scratched. leave it in gear and tape the front brake lever back so it doesn't roll about.
Ditto
PostPosted: 22:08 - 16 May 2010    Post subject: Reply with quote
Ive seen those exact photos with that username on the Bandit forum...
https://strategicdc.com/blog/wp-content/uploads/2010/04/detective.jpg
Razz
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
Misc
PostPosted: 22:23 - 16 May 2010    Post subject: Reply with quote
Now that you say that i do remember pulling a clump of wool looking material from the sprocket. No idea where it comes from.
Will do this method. Thanks.
Razz
Yup, tis me. I was in need of urgent help. But BCF came through faster. Wink The Bandit forum is really good though, some great advice & a nice bunch of people.
Misc
PostPosted: 18:27 - 18 May 2010    Post subject: Reply with quote
Another bump, sorry.
Adjusted it a couple of times but when the bike's cold the revs mover faster then usual, as if you've pulled in the clutch.
Does the adjusting bolt need to be screwed in more or screwed out? What way is engaging the clutch?
PostPosted: 19:42 - 18 May 2010    Post subject: Reply with quote
Firstly loosen off the cable at the cable adjuster. this is an important step.
Next, release the locknut on that clutch pushrod adjuster. After that, turn the center adjuster anti-clockwise until it goes loose, and there's no weight pushing on it. Now wind it in until you feel it contact the pushrod behind the cover. When you feel contact, turn it back out half a turn and tighten the locknut without letting the adjuster turn any further in.
Now adjust the cable to take up most, but not all, of the free-play.
Misc
PostPosted: 19:58 - 18 May 2010    Post subject: Reply with quote
Hi,
I did the above but couldn't really feel any resistance until it was screwed most of the way, would the 'contact' be barely noticeable or would i definitely know? I'll give it another go tomorrow. When Keith said similar to the above i didn't back off half a turn after i tightened it, does this make much difference?
And with the last bit, when you say adjust the cable for the free play, are you talking about the adjusting screw at the lever, as i don't have one. Embarassed
PostPosted: 17:41 - 20 May 2010    Post subject: Reply with quote
The cable adjuster is right there in your photo. It's the screw and locknut which screws into the top of the case. Wind it all the way in so there's no threads showing before you adjust anything.
The adjuster is the screw with the slot in the end. Turn it anti-clockwise until it's very loose. Then turn it clockwise until you feel it touch the pushrod. You will feel it touch but it won't go tight. After that turn it back half a turn and lock it with the nut.
When you have done all that wind the cable adjuster in the top of the case out again. When it was wound right in you would have had a lot of loose play at the lever. You need to reduce that looseness, but not all of it. if you take it all out it will start pulling on the release arm and make the clutch slip. after you have adjusted the cable free-play, wind that nut on the adjuster down the thread so the nut tightens on the case. This will stop the adjuster from un-adjusting itself in use.
Misc
PostPosted: 21:40 - 20 May 2010    Post subject: Reply with quote
Thanks again.
I know the cable adjuster but not sure what you mean the second bit, are you talking about the second photo? Wondered what the hell that was. Embarassed
I'll give this a go tomorrow. Thumbs Up
PostPosted: 23:09 - 20 May 2010    Post subject: Reply with quote
Yes the second photo. Have you not adjusted that bit? That is the clutch ajuster, that you must wind out then in till it touches then out half a turn. Remember the big nut locks it, so loosen that a bit first and tighten it last.
Misc
PostPosted: 23:23 - 20 May 2010    Post subject: Reply with quote
I understand now. Nope, not adjusted that bit. I did think it must be for something as i dissembled that part with all the tiny bearings but thought it just held the shaft in.
Cheers.
Misc
PostPosted: 18:32 - 21 May 2010    Post subject: Reply with quote
Got round to adjusting it today, it's much better now. Thanks Guys/Pete. Clutch lever has more play then normal & the biting point is much closer but feels easier to control now.
The last post was made 16 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.23 - MySQL Queries: 16 - Page Size: 112.17 Kb
