| Misc |
 Misc World Chat Champion
 Posted: 23:19 - 19 May 2010 Post subject: 'Stiffening' up headlight bracket |
Hello again,
Fitted my new headunit today but the joints aren't very stiff so a strong wind or a bump could move the headlight position. From the photo below, what can i do to stiffen this up to make it harder to move. It's mainly just the joint that is marked below. I've tried to fit a metal/rubber washer but the gap is far too small, i added electrical tape which helped a bit but even that was a struggle to even get the bracket in. Any ideas?
Cheers.
https://img12.imageshack.us/img12/5103/ovalchromklar224330.jpg
https://img514.imageshack.us/img514/5103/ovalchromklar224330.jpg |
| MarkJ |
 MarkJ World Chat Champion
| Misc |
| MarkJ |
 Posted: 23:45 - 19 May 2010 Post subject: |
Yeah definitely make sure it's in a position you like
Part of me wonders about drilling a notch of some sort in it, or maybe drill a thin hole through both arm and bracket allowing you to fit a dowel of some sort in? Probably not enough room for that though
What about bending a flat metal bracket that hooks through the hole in the arm and goes around the back of the bracket, stopping the arm putting itself downwards? If you found a way of securing it at the back you could probably even do this with some wire. |
| temeluchus |
| Misc |
 Posted: 23:51 - 19 May 2010 Post subject: |
Cheers guys, i'll attempt the easiest method first & have a think about some sort of bracket but if all that fails i'll get some glue.
| richbike |
 richbike Two Stroke Sniffer
| Grimnir |
 Grimnir Trackday Trickster
| Walloper |
 Walloper Super Spammer
| defblade |
 defblade World Chat Champion
 Posted: 10:20 - 20 May 2010 Post subject: |
I'd be filing some of the shiny smooth chrome away where the light mounts, both on the light and the bracket, so there's more friction between them. And if that's not enough, star or spring washer as mentioned. And doing the bolt up bastard tight. ____________________ Honda Varadero 125cc => Suzuki Bandit 650 33bhp => 77bhp =>
BMW K1200R Sport 163bhp => Aprilia Shiver GT 750 95bhp |
| Misc |
| MarkJ |
 Posted: 00:08 - 21 May 2010 Post subject: |
Nice, glad it's sorted
What's that headlight like in the dark? |
| Misc |
 Posted: 08:13 - 21 May 2010 Post subject: |
Keep an eye on that - looks like it's likely to wobble the light and the bolts will come loose. ____________________ a.k.a 'Geri'
| Misc |
The last post was made 16 years, 1 day ago. Instead of replying here, would creating a new thread be more useful? |
