| BenR |
 BenR World Chat Champion
 Posted: 15:47 - 22 May 2010 Post subject: Misfire RG125UN wolf. |
Hi I have a few electrical gremlins the main one being a misfire from 6000rpm through to 8000rpm on my RG. I have replaced the stator/magneto (thinking of the pickups) I've also replaced the coil & CDI unit. I'm at my wits end really as I've just restored this bike & just want it to run right. Could the regulator/rectifier have anything to do with the ignition? It does charge fine. Any help much appreciated cheers!  ____________________ Current bikes: suzuki RG125UN wolf. Yamaha MT-07 |
| BenR |
 Posted: 17:52 - 22 May 2010 Post subject: |
Anyone?  ____________________ Current bikes: suzuki RG125UN wolf. Yamaha MT-07 |
| BenR |
 Posted: 09:03 - 23 May 2010 Post subject: |
Would appreciate some help guys cheers.  ____________________ Current bikes: suzuki RG125UN wolf. Yamaha MT-07 |
| P.addy |
 P.addy Red Rocket
| BenR |
| Crafty |
 Crafty Derestricted Danger
| Kickstart |
 Kickstart The Oracle
| BenR |
| cb1rocket |
 cb1rocket World Chat Champion
| Kickstart |
| cb1rocket |
| Kickstart |
| Crafty |
 Posted: 15:00 - 25 May 2010 Post subject: |
The more I think about this, the more I think you'll find its a carb issue. If it was electrical it would happen randomly & at any rpm.
Try the circlip on the needle. Lower it (bottom groove) to increase fuel mixture & raise it (top) to weaken mixture. Also the wet plugs are probably due to you NOT shutting the throttle &/or failing to pull the clutch lever just before you hit the kill switch? You must do both or the engine will pull in air & fuel, resulting in an inaccurate reading & a very wet plug. EITHER coast to a stop with clutch lever pulled in, or find neutral before releasing clutch lever.
The carb has 3 main phases, but each slightly overlaps the next
1) idle to 1/4
2) 1/4 to 3/4
3) 3/4 to full
Phase 1 is controlled by the pilot jet & the air screw.
Phase 2 is controlled by the needle valve.
Phase 3 is controlled by the main jet.
So by using these factors obviously air screw & pilot jet are eliminated.
Next thing to do is get the full throttle mixture right so that the much more complex process of getting the needle set up can be sorted, (once this is done a further full throttle plug chop will be needed. To make sure its not too lean. It's better to run a little on the rich side tbh).
Next thing to check is if its happening only in Phase 2, Phase 3 or both?
The needle valve works like a tap on your sink below 1/4 it fills the hole in the main jet shutting off all supply, then as you go above 1/4 it starts to allow a little fuel in, then as you open it more the taper allows even more fuel though the main jet. Then @ around 3/4 open it allows maximum fuel through the main jet. At this point the main jet take over. That is why the needle is tapered & also why its misleadingly called a jet. In truth it is actually a main jet variator.
It has to be remembered that this is throttle openings & IS NOT RPM RELATED
Also check that the needle is neither bent or worn. this will be obvious as the taper should be nice & even. no ruts, dents, rings or grooves etc etc.
This I suspect is the real problem so EXAMINE IT VERY CAREFULLY. Either that or its way too rich.... if your @ full throttle opening when it happens, try backing off to 3/4 if thats the case.... if it clears itself then you know for sure it a fueling problem,
Hope this helps. ____________________ To FINNISH 1ST, 1ST you gotta FINNISH.
Fastest is the 1ST to CROSS the FINNISH LINE.
2ND, IS the 1ST of all the LOSERS. |
| BenR |
 Posted: 19:23 - 25 May 2010 Post subject: |
| Crafty wrote: | The more I think about this, the more I think you'll find its a carb issue. If it was electrical it would happen randomly & at any rpm.
1) idle to 1/4
2) 1/4 to 3/4
3) 3/4 to full
Hope this helps. |
Thanks very much guys.  ____________________ Current bikes: suzuki RG125UN wolf. Yamaha MT-07 |
| BenR |
 Posted: 17:22 - 28 May 2010 Post subject: |
Hi all. I've narrowed it down to the carb. I ordered all new jets today but unfortunately the part I really needed/wanted (jet needle) is now unavailable. I'm at a loss as to what I can do now any suggestions much appreciated cheers.  ____________________ Current bikes: suzuki RG125UN wolf. Yamaha MT-07 |
| Kickstart |
| BenR |
The last post was made 16 years, 81 days ago. Instead of replying here, would creating a new thread be more useful? |
