RS50 Think its slippigg
Stefan RS50 Wood
PostPosted: 17:05 - 26 May 2010    Post subject: RS50 Think its slippigg Reply with quote
New to this 1st Post Smile
My rs50 , 53reg is slipping like when i drive it, i can be in gear 6 and its red lining at like 20mph, but if i stay below 7revs its fine
how hard is it to fit new clutch plates because i think its that
Thx
Crafty
PostPosted: 18:07 - 26 May 2010    Post subject: Reply with quote
Very easy if you know what your doing, & fairly easy even if you don't, but can wield a spanner.
If in doubt get a pro to do the work.
You will need a clutch holding tool, a new sets of plates, a new set of springs & a clutch cover gasket as well. Fresh engine oil because its wet multiplate which means the oil in the gearbox is used to cool & lube the clutch.
First of all, remove fairing lowers & bellypan to reveal engine.
Remove sump plug (14mm socket fits I think?) & drain gearbox oil, clean sump plug of debris & refit. Remove clutch crankcase cover to expose clutch basket. Carefully unbolt the retaining bolts USING CLUTCH HOLDING TOOL to stop it from rotating, remove springs remove all plates. Fit new plates in same formation as old ones removed. Fit NEW SPRINGS as well clean engine casing & clutch cover mating surfaces, fit a new gasket, refit cover fill with fresh 10/40 oil adjust clutch & thats it basically.
https://www.ultimateparts.net/info/aprilia-bikes-rs/aprilia-bikes-rs.php?bike=354
https://www.ultimateparts.net/aprilia/a.php?n=AP8201527-Clutch-lock-ENGINE-TOOL-KIT-Aprilia-Special-Tools-D-Minarelli-AM6-Aprilia-Tools&i=338347
To FINNISH 1ST, 1ST you gotta FINNISH.
Fastest is the 1ST to CROSS the FINNISH LINE.
2ND, IS the 1ST of all the LOSERS.
Faraz
PostPosted: 19:47 - 26 May 2010    Post subject: Reply with quote
It's very easy.
I did it and the only tools I needed were a couple of allen keys IIRC.
Drain coolant, drain gearbox oil, remove cover, remove pressure plate, remove clutch and steel plates, fit new plates in the same order as you removed them. Dip the plates in a little gearbox oil before you put them in.
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
Stefan RS50 Wood
PostPosted: 22:09 - 26 May 2010    Post subject: Re: RS50 Think its slippigg Reply with quote
Thx
Thanks im not too bad with bikes soo ile have ago, i can get the plates off adrenaline pedstop for 20quid with the springs and whats this Gasket i will need ?
PostPosted: 22:18 - 26 May 2010    Post subject: Reply with quote
Before replacing the clutch plates, what oil is in the gearbox and is the clutch adjusted properly?
Stefan RS50 Wood
PostPosted: 22:47 - 26 May 2010    Post subject: Reply with quote
the right 1 as just got back from service and asked them to try sort clutch out but they told me i need new plates so gota get them
Faraz
PostPosted: 11:31 - 27 May 2010    Post subject: Reply with quote
The gasket you need is for the clutch cover.
You can get is from a main dealer or find it online.
Getting it from a Yamaha dealer is probably your best bet. Clutch cover gasket for a TZR50.
'56 Yamaha MT-01
There is a gap of 3 years, 179 days between these two posts...
Scott richards
PostPosted: 12:30 - 21 Nov 2013    Post subject: aprilia rs 50 Reply with quote
i have a aprilia rs 50 and when i hit 8000 revs the clutch kicks in a bit a slows me right down do i need new clutch plates?
srichards
nathan k
PostPosted: 12:47 - 21 Nov 2013    Post subject: Re: aprilia rs 50 Reply with quote
Wut? Do you mean the clutch slips at 8k, as in the revs suddenly jump up but your speed doesn't?
It's more then likely your clutch cable stretching overtime and just needs adjusting (the screw bit on the lever). Try loosening it a little if it's slipping.
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.33 - MySQL Queries: 16 - Page Size: 69.14 Kb
