Rear sprocket nuts
bacon
PostPosted: 10:21 - 29 May 2010    Post subject: Rear sprocket nuts Reply with quote
Just a quickie to help my bro, he has a CBR600f 2001
There are some kind of honda lock nuts on there atm holding the rear sprocket on, is it ok to change them to some nylon lock nuts (half the thread is nylon) to save buying some overpriced honda ones?
Just wondering if they can handle the torque as well as the honda ones
PostPosted: 11:01 - 29 May 2010    Post subject: Reply with quote
Decent quality nylok nuts should be fine. You might want a washer under them because as I recall, the original ones will be shouldered nuts.
The stud is weaker than the nut that goes on it anyway.
27cows
PostPosted: 13:09 - 29 May 2010    Post subject: Reply with quote
I would only use lock washers on rear sprocket nuts as I've seen nylocs/the like come undone. If you do use nylocs, put a bit of thread lock on as well, to reduce the chance of the nuts working undone.
PostPosted: 21:15 - 29 May 2010    Post subject: Reply with quote
For reasons I wont go into here. If you have torqued them up to the correct tension, they shouldn't come undone anyway. The nylok is just the icing on the cake.
The original nylok style nuts honda fit as standard are pretty half-arsed affairs as it is. Not much in the way of nylon or lock about them.
bacon
PostPosted: 14:14 - 30 May 2010    Post subject: Reply with quote
Thanks for your advice, much appreciated
DrDonnyBrago
PostPosted: 20:33 - 30 May 2010    Post subject: Reply with quote
Thanks all Thumbs Up .
The last post was made 15 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 16 - Page Size: 48.35 Kb
