argh ffs
woll
PostPosted: 10:17 - 30 May 2010    Post subject: argh ffs Reply with quote
My bandit had a slight leak on the sump plug and the oil looks fairly fresh (only had it a week) so i thought ah it's not been tightened up quite enough or the washers foobar (so i ordered a new sump plug with washer), put spanner on went to tighten it and it felt like it had was coming undone. I new exactly what had happened, i was hoping that it hadn't but it has, i slowly undid the sump plug and low and behold the threads started falling onto my hand Crying or Very sad Crying or Very sad.
https://i649.photobucket.com/albums/uu211/whalley1992/Bikes/DSC00398.jpg
That's what i was met with. Some gorilla has overtightened the sump plug and stripped the threads out of the engine. Thumbs Down the new sump plug will tighten up to a certain point then it just goes loose.
I did the same thing on my 50cc bike a few years back Embarassed and plumbers ptfe tape managed to seal it. So i thought it was worth a go on the bandit. I've put some on the nut and tightened it up and it does go tight at the top. Will i be ok to torque it to the manufacturers spec? Or will it just do the same again?
Will it do as a fix or should i book it into a garage to have it helicoiled or sumat? And what kind of price should i expect to pay?
Ta lads
steveh
PostPosted: 10:29 - 30 May 2010    Post subject: Reply with quote
it will leak again, simple as.
Either tap it out and find a bigger plug, or take the sump plate? off and get it helicoiled, not expencive really, or get a kit and do it yourself.
If you bodge it and it fails, its likley to go all over your rear wheel and spit you off or kill you, is it worth the risk?
do the job properly then you dont have to worry about it anymore.
steve.
woll
PostPosted: 11:11 - 30 May 2010    Post subject: Reply with quote
Would it be as simple as just getting the right size tap and tapping it out? or would i have to take the sump off and drill it? or some other procedure?
woll
PostPosted: 11:36 - 30 May 2010    Post subject: Reply with quote
Vincent wrote:
You need to drill the hole the right size for the helicoil first and need the tool to insert it. Not sure how well it would work in this instance.
I wasn't sure myself how it would be done Confused i've used helicoils before and im sure that there needed to be an end to the thread if you get what i mean, as surely the sump is just threaded all the way through so the helicoil would just screw straight through Confused or is that no the case?
Was hoping i could of had it sorted for tomorrow, no chance of that Thumbs Down was meant to be going out on the bike Crying or Very sad
woll
PostPosted: 12:23 - 30 May 2010    Post subject: Reply with quote
Depends on what you mean by a plate? It has a removable sump, so i could just unbolt it then either do it myself or get somebody else to helicoil it.
Would it be possible to use some instant gasket on the sump if i take it off? Monies going to be tight for a week or two and i need the bike for work and i've got instant gasket in the shed.
woll
PostPosted: 12:57 - 30 May 2010    Post subject: Reply with quote
Well looks like im taking my sump off tomorrow Laughing i have a feeling the downpipes will have to come off too Sad Confused i hope whoever put stainless pipes on put some copperslip on the studs Confused
Ah well gives me chance to do the fork seals i suppose.
Don't suppose anybody knows if i can change them while the forks are still on the bike? I've only got my MX bike lift and it wont fit under the bike to take them off.
Ooo and i can polish the downpipes if i get them off lol
PostPosted: 15:35 - 30 May 2010    Post subject: Reply with quote
You don't need a blind hole to fit a helicoil. I fitted one in my 'busa sump. When you use the insertion tool to fit the coil it works by twisting the spring which reduces the diameter allowing it to screw into the thread you cut. WHen you stop turning the spring expands and grips into place. You then snap the tang off.
You don't need to strip the sump off if you can get on it with the helicoil tool either. There will be a minimal amount of swarf but a quick oil change will shift that and any not carried out by that will be left harmlessly in the bottom of the sump.
woll
PostPosted: 16:54 - 30 May 2010    Post subject: Reply with quote
Oooooo sounds good to me pete Thumbs Up local engineering place is 3 miles away and im 100% that they could helicoil it, i may just bodge it to seal then ride it there and get them to helicoil it. Unless i find somebody with a helicoil kit, cos i dont fancy paying £50 for something im only going to use once lol
woll
PostPosted: 18:25 - 30 May 2010    Post subject: Reply with quote
Any tips on doing my fork seals? never done any before, i have got a haynes but i find them confusing at times lol. I presume i will have to take the forks apart or will i be able to do them while they're on the bike? And what weight and how oil do the bandit 600 forks need?
GSF Jamie 600
PostPosted: 18:41 - 30 May 2010    Post subject: Reply with quote
when fitting the forks back together, use a torque wrench and set all the three bolts to 23 NM Thumbs Up
woll
PostPosted: 12:32 - 02 Jun 2010    Post subject: Reply with quote
Hellllppppp lol
Took the left hand fork off the bike today 'cos all the bits have come. Thought i was doing well, got the wheel off, turned the dampner bolt in the bottom of the stanction, undid the top bolt, took it off the bike. Then went to completely undo the damper bolt but it just turns Evil or Very Mad So i put forks back together and onto the bike tried again but it wouldn't undo. I pulled it in all different ways put forks together put weight on them and tried to undo the damper bolt but i can't Sad anybody got any ideas on how to do it? I can't afford to pay somebody to do it.
woll
PostPosted: 12:57 - 02 Jun 2010    Post subject: Reply with quote
Yeah i just read on the internet bout using a broom handle, so i fettled the end of the handle to a similar shape of the tool suzuki use and the bloody broom handle snapped when i turned the allen key leaving me with a chunk of broom handle inside the stantion that i can't grip.
So much for what i read about it only being a 2 hour job for the seal replacment lol
woll
PostPosted: 13:16 - 02 Jun 2010    Post subject: Reply with quote
Going to have another brew brake lol getting wound up with it now Twisted Evil Evil or Very Mad
DrDonnyBrago
PostPosted: 13:44 - 02 Jun 2010    Post subject: Reply with quote
Never had much success with the broom handle either tbh, it needs a short sharp whack to undo the bottom damper bolt.
A mechanics airgun is perfect and will usually do it in no time either for free or for a few quid of beer money.
woll
PostPosted: 13:57 - 02 Jun 2010    Post subject: Reply with quote
Sad no mechanics like that round here, all want stupid amounts for little work (the ones i know anyway). I know one of my bosses has an impact gun for his compressor but its fooking huge iirc its 3/4 drive so no chance of using that for the job Sad
woll
PostPosted: 14:55 - 02 Jun 2010    Post subject: Reply with quote
Just to check, if i do get hold of an impact gun. Do i still need the tool to hold the insides?
And so that im not fucking around for days, do i need to get the damper out to remove the stanction? or do i just need to give the stanction a good pull?
And is it right that i might be able to use a self tapping screw to pull the oil seal out?
The last post was made 15 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.54 - MySQL Queries: 16 - Page Size: 144.04 Kb
