SV650s Brake disc's. Should I be worried?
PostPosted: 20:52 - 31 May 2010    Post subject: Reply with quote
Don't.... quite... understand?
Do you mean the discs are spinning in the same plane as the wheel? or that they move side to side?
DrDonnyBrago
PostPosted: 21:05 - 31 May 2010    Post subject: Reply with quote
Do you mean it has floating discs?
PostPosted: 21:38 - 31 May 2010    Post subject: Reply with quote
warped one wrote:
Sorry for my crappy explanation, here is a crappy paint diagram
Which plane can you wobble the disc on? The same plane as the rotation of the wheel?
PostPosted: 21:56 - 31 May 2010    Post subject: Reply with quote
warped one wrote:
Side to side, forward and back.
In order to describe this, you need a frame of reference. Please provide a frame of reference to the movements you describe...
Seb
PostPosted: 00:17 - 01 Jun 2010    Post subject: Reply with quote
I think I get what you mean, my GS's front disk is pretty similar, it alarmed me when I could hear the disk clicking when I was on the front brake fairly hard, spooked me enough that I didn't touch that front brake lever again till I'd had a few words with a couple of mechanics Smile
It's down to wear on the rivets afaik.
2010 Triumph 1050 Sprint ST
PostPosted: 00:57 - 01 Jun 2010    Post subject: Reply with quote
warped one wrote:
I would have thought that or the seat the rivets sit in. Either way the bike was bought 4days ago. And tonight after a run to squires and back 150miles. It would not start so another problem.
Should said friend return the bike 50mile away or get local garage to look at it?
Basically i'm trying to either stop him from killing himself or looking a muppet.
If he bought it from there, take it back and demand they re-service the bloody thing before he spends cash on it/kills himself..
Blue_SV650S
PostPosted: 08:26 - 01 Jun 2010    Post subject: Reply with quote
The standard SV650 discs have no notable 'float'. Are the discs standard SV ones or after-market ones like the wavy ones you drew on above?
I have seen some discs (not SV650 standard ones) that flap about a fair bit, so wouldn't be too concerned as long as it isn't a standard SV disc and a quality aftermarket make. But if it is a cheap replacement disc, the bobbin bits or the hub part of the disc might be made of cheap stuff are probably pretty worn ...
A small amount of play in a stock or quality disc I wouldn't be concerned about ... if it is a cheap aftermarket disc, then it might be ok right now, but if it has worn that quickly it could continue to get worse to the point it is a problem (the bobbing would have to be VERY worn for this to happen mind-ewww) ....
Damon
PostPosted: 10:18 - 01 Jun 2010    Post subject: Reply with quote
As above, if it is a fully floating aftermarket disc then I wouldn't worry too much. If it is a standard SV disc though they shouldn't really have any play in them what so ever.
PostPosted: 11:57 - 01 Jun 2010    Post subject: Reply with quote
5mm sounds rather a lot of play. My Bimota disks are fully floating and do have a fair amount of play, but even they don't have that much.
Gazdaman
I did a trackday!!!
PostPosted: 12:00 - 01 Jun 2010    Post subject: Reply with quote
Those rivets should spin, and the disk should have slight side to side movement. I.e across the bike in the same direction as the handlebars travel.
But not much movement.
Gaz
Ed Case
PostPosted: 20:29 - 01 Jun 2010    Post subject: Reply with quote
I used to have a Laverda triple fitted with Brembo 300mm 'full-floaters' which rattled side-to-side from new and was ok but fore and aft slop meant that they were knackered and needed replacing. Invest in a couple of new ones my mate, you've only got one life.
Blue_SV650S
PostPosted: 00:16 - 02 Jun 2010    Post subject: Reply with quote
Gaz
The stock SV ones have no notable movement in any direction ... there is no way you can freely rotate the rivets ...
The last post was made 16 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.24 - MySQL Queries: 16 - Page Size: 100.98 Kb
