What is this part? :/
Bambam3
PostPosted: 11:10 - 07 Jun 2010    Post subject: What is this part? :/ Reply with quote
Hi guys, recently removed the back tyre for the first time in order to get a puncture fixed at a shop.
All went quite well, except when I removed the thing from the side of the tyre/bike, on the opposite side of the sprocket.. a little thing fell out as I carried it into the garage with all the other bits.
It's a Honda XR125.
I've circled the main thing I think it fell off as I carried it away from the bike:
https://img143.imageshack.us/img143/6296/wtf2d.jpg
And here's a crude drawing of the part. It's pretty small, a few cm long/wide with a hole through the middle, cylindrical a bit. :
https://img717.imageshack.us/img717/6509/whatisits.jpg
I don't have pics as it's at a friends (closest to me at time of puncture). Going to pick up tyre now shortly so hopefully someone will clue me in before I get sorted and mess this up.
Cheers in advance. Thumbs Up
Raffles
PostPosted: 11:26 - 07 Jun 2010    Post subject: Reply with quote
I'm guessing that it is the part that connects the brake actuating lever to the rod from your rear brake pedal.
el_oso
PostPosted: 11:35 - 07 Jun 2010    Post subject: Reply with quote
if you could get a picture of the part im sure it would jog my memory. try the sticky thread for the workshop manual. there is one but it is in Spanish. shouldn't matter though because you just need the pictures
Duke 390
Car: Jeep Wrangler 4.0L
Dazbo666
PostPosted: 12:01 - 07 Jun 2010    Post subject: Reply with quote
https://i42.photobucket.com/albums/e312/Dazbo666/Bike%20Bits/wtf2dedit.jpg
Word of the day : DILLIGAF
Grimnir
PostPosted: 12:04 - 07 Jun 2010    Post subject: Reply with quote
There may possibly be a nut that goes on the threaded rod as well
Bambam3
PostPosted: 12:12 - 07 Jun 2010    Post subject: Reply with quote
There were nuts on there yeah, got them. Thumbs Up
PostPosted: 12:53 - 07 Jun 2010    Post subject: Reply with quote
If it's the bit off the brake rod, it's called a brake trunnion.
https://i48.photobucket.com/albums/f216/stinkwheel/drumbrake/Image016.jpg
Bambam3
PostPosted: 12:55 - 07 Jun 2010    Post subject: Reply with quote
Brilliant, cheers guys. Thumbs Up
Grimnir
PostPosted: 13:29 - 07 Jun 2010    Post subject: Reply with quote
A far more informative pic!
yen_powell
PostPosted: 13:32 - 07 Jun 2010    Post subject: Reply with quote
Isn't trunnion a most delightful word! Very Happy
I must try and think of reasons to drop it into casual conversation.
XT1200Z and a DR350 in bits
Dazbo666
PostPosted: 13:58 - 07 Jun 2010    Post subject: Reply with quote
Stinkwheel to the rescue. I recognised the part, but had no idea of the specific name Thumbs Up
Alexio
PostPosted: 14:19 - 07 Jun 2010    Post subject: Reply with quote
If your rear brake has stopped working once you've got it all back together again this would be why!
Bambam3
PostPosted: 17:54 - 07 Jun 2010    Post subject: Reply with quote
That it was, big thanks guys. Thumbs Up
Managed to put the wheel back on and rode home without killing myself. Accomplishment +1.
PostPosted: 20:46 - 07 Jun 2010    Post subject: Reply with quote
You should have had either one odd-shaped nut or a pair of normal nuts on the brake rod that went through that trunnion. Since you didn't recognise it I'll run you through the adjustment process that I use.
If you had one special trunnion nut with a larger hex and a half-round cutout that fitted against the trunnion, then you lift the rear wheel off the ground and wind the trunnion nut over and over the 'lumps' until you feel the wheel binding as you turn it by hand AFTER it has hit, then back off the trunnion nut until there is no drag at all. Finally test the system by turning the wheel with one hand and repeatedly pressing the footbrake with the other to make sure it runs freely when it releases each time.
If you had two normal nuts then wind the first one on whilst turning the wheel by hand. When you feel it starting to bind back off the nut two turns and check the wheel's not binding. Now run the second nut up to the first and lock them together to stop them loosening off. Now check the wheel for brake binding again.
The last post was made 16 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.19 - MySQL Queries: 16 - Page Size: 86.65 Kb
