Removal off restrictors
LevsFZS600
PostPosted: 02:39 - 12 Jun 2010    Post subject: Removal off restrictors Reply with quote
Got a FZS600 2000 reg, carb restrictors.. want to get these taken out, just need some advice or tips on what to do once i get to the carbs, and if anything needs changing once there out,
thanks in advance
Owner OF 2000 FZS Fazer 600 Smile
oriel dave
PostPosted: 10:48 - 12 Jun 2010    Post subject: Reply with quote
If they're washers it's literally just a case of taking them out. You might want to balance the carbs afterwards although I found mine didn't need it.
Europe Trip 2009
0l0dom0l0
PostPosted: 19:12 - 12 Jun 2010    Post subject: Reply with quote
when people had the restrictors in, did they find the bike struggled to rev past 6k in neutral. i have just fitted some, and it wont rev past 7000 very well atall?
also, any chance you can measure the sizes of the holes on the restrictors? i think my hole was 12mm, but i want to check that its the right size.
thanks
PostPosted: 19:22 - 12 Jun 2010    Post subject: Reply with quote
The restrictors will surely affect the running, but not revving in neutral is odd.
Did you put them in between the carbs and engine or in between the airbox and carbs?
Were the holes off-set or in the middle of the restrictors? If off-set, did you put them in with the holes lowest, or just anyhow?
0l0dom0l0
PostPosted: 20:08 - 12 Jun 2010    Post subject: Reply with quote
holes were in the middle. between the engine and carbs. the carbs are seated properly etc. the bike will rev past 6k, but very reluctantly. its basically just an overexagerated flat spot i think?
The last post was made 15 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 16 - Page Size: 50.44 Kb
