flushing cooling system out
PostPosted: 23:51 - 18 Jun 2010    Post subject: Reply with quote
Water, from a hosepipe.
Park the bike near a drain. Leave the drain plug(s) out. Put the hose in the top, turn it on at a steady trickle, go have a cup of tea.
PostPosted: 00:53 - 19 Jun 2010    Post subject: Reply with quote
I suppose the two questions you need to ask yourself are:
1) Does something make you thing your cooling system is operating below optimum? Does it actually need to be flushed out at all?
2) What exactly is it you are trying to flush out? In an aluminium engine which has had a modern, corrosion inhibiting coolant in it, I'd have said there is somewhere between little and nothing to flush out of there. At worst the last vestiges of the old coolant.
I've never found significant deposits of anything much in the cooling system on a modern bike engine. Even if you go into the waterpump/thermostat chamber where sludge and grot would collect.
On a cast iron diesel engine, yes, you can get all sorts of rusty yuck in there with high mileages (like 100k +).
If you'd had a leaky mechanical seal in the waterpump or a blowing head gasket, there could be oil contamination and possibly mayonaise in there that would probably be better rinsed out.
Collect the old coolant in a bucket, see if there is any sludge/detritus in it. If there is, maybe worth giving it a flush out. If there isn't, why bother?
Serendipity
PostPosted: 09:47 - 19 Jun 2010    Post subject: Reply with quote
I had a seal fail in the oil cooler of my CBR600 that dumped a load of oil into the cooling system. The CBR600F oil cooler lives in a little water jacket at the front of the motor.
After I replaced the seal I flushed the system with absurd amounts of fresh water. I’d already had the radiator off and flushed that separately, but once that was refitted I ran loads of water through from a hose pipe. Once that was all running clear I went through a process of filling the system with fresh water and warming the engine to running temp, then draining and repeating. I spent an entire afternoon filling, warming and draining steaming hot water.
Sort of like a very expensive kettle. Smile
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
PostPosted: 10:08 - 19 Jun 2010    Post subject: Reply with quote
You should have mixed up a strong mix of hot water and detergent (fairy liquid) and put that in, then run the bike for a few seconds to break down the oil emulsion. Would only have needed one fresh-water flush then.
Serendipity
PostPosted: 10:58 - 19 Jun 2010    Post subject: Reply with quote
That too. Smile
Yes I did run a cocktail of Fairy through, hence the excessive rinsing. Dunno about you, but I'd rather not leave highly corrosive substances in the cooling system.
PostPosted: 11:14 - 19 Jun 2010    Post subject: Reply with quote
Like tap water you mean? Very Happy
PostPosted: 11:23 - 19 Jun 2010    Post subject: Reply with quote
Does it not depend where you live? My tap water is bottle standard Wink
PostPosted: 12:42 - 19 Jun 2010    Post subject: Reply with quote
To flush a radiator I tend to disconnect the pipes from it to the engine, and connect a hose pipe the blast it through (normally in reverse of the normal direction first).
puremagic72
PostPosted: 18:18 - 19 Jun 2010    Post subject: Reply with quote
50% white vinegar and 50% distilled water, run your bike for a few minutes with it in, then empty, and flush it all out with a hose for a while, then refill with coolant!
Best way to get any crap out.
Baz. Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
The last post was made 16 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.69 - MySQL Queries: 16 - Page Size: 80.76 Kb
