Batterry Urgent Query ..
Mr.Everready
PostPosted: 15:23 - 01 Jul 2010    Post subject: Reply with quote
Take the battery out and see if there's a fill level.
johnsmith222
PostPosted: 15:26 - 01 Jul 2010    Post subject: Reply with quote
They're supposed to be filled up to a line or marking.
You can just use tap water if you have decent water. Distilled water is better though.
kt
PostPosted: 15:33 - 01 Jul 2010    Post subject: Reply with quote
You can buy distilled water in most motor factors but if you are stuck top up with clean rainwater but not tapwater.
Inkognito
PostPosted: 15:42 - 01 Jul 2010    Post subject: Reply with quote
The last battery i bought was no where near full to the top when it was filled with the stuff it came with.
But charged fine and still works ok.
Is for a scooter though. No idea if it makes a difference.
Mr.Everready
PostPosted: 15:44 - 01 Jul 2010    Post subject: Reply with quote
Black cable first.
Mr.Everready
PostPosted: 16:05 - 01 Jul 2010    Post subject: Reply with quote
Water will be fine if it's just a top up.
WD Forte
PostPosted: 16:09 - 01 Jul 2010    Post subject: Reply with quote
IF you buy some distilled or deionised water from a shop
you can top up both the battery and coolant with that.
If the battery does not have hi/lo lines, just make sure the
electrolyte level is above the plates by say 5-6mm
It doesnt need and should not be, full to the brim!
bikers smell of wee
WD Forte
PostPosted: 17:15 - 01 Jul 2010    Post subject: Reply with quote
Not sure about the theory test
we didnt have them when I were a lad
In short.
The electrolyte (dilute sulfuric acid) must cover the plates and you need an air gap between that
and the overflow and filler plugs
Spilt electrolyte will do damage to the bike
Battery Connections
Disconnecting:
Pos then neg
Connecting :
Neg then pos
Coolant
Tap waters often fine but in hard water areas too much may lead to 'furring'
just like in domestic plumbing so that why distilled or rain water is
recommended.
You also need to maintain the ratio of water to anti freeze which also prevents
corrosion usually at say 25%.
Tyre pressures:
As I dont know what bike or tyres you use
and bearing in mind you say youre a big chap, I'd go with the
makers 2 up recommended pressures and see how it feels.
later You can make adjustments to suit.
Weather etc
There are so many variables to consider when riding bikes that its safer to say that
how you ride determines how long you ride
Generally speaking, in the wet 'Ride easy'
never assume that because you have expensive tyres you wont fall off.
bikers smell of wee
Inkognito
PostPosted: 18:17 - 01 Jul 2010    Post subject: Reply with quote
WD Forte wrote:
Battery Connections
Disconnecting:
Pos then neg
Connecting :
Neg then pos
So black cable off first was wrong?
I don't know how you guys remember that. i can never remember which one first lol
2wheelsteve
PostPosted: 18:34 - 01 Jul 2010    Post subject: Reply with quote
Leave tap water 24hrs in a jar but really you can just use it str8 from the tap
WD Forte
PostPosted: 19:03 - 01 Jul 2010    Post subject: Reply with quote
TBH
I dont bother with the pos neg order much myself but
The theory is that if theres a load present
the possible arcing caused when connecting and disconnecting
the terminals could ignite the hydrogen gas given off by the battery.
If you have no load such as alarms clocks or other gizmos etc
then the order you remove terminals isnt so important.
bikers smell of wee
wristjob
PostPosted: 20:18 - 01 Jul 2010    Post subject: Reply with quote
WD Forte wrote:
Battery Connections
Disconnecting:
Pos then neg
Connecting :
Neg then pos
the problem with that method is
that is your spanner makes contact with the frame or anything else thats earthed while playing on the + terminal then you get the whole arc welder effect(if continued makes a bomb!)
where as doing the reverse of what you suggest removes all of that risk
The last post was made 16 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.38 - MySQL Queries: 16 - Page Size: 111.24 Kb
