Should there be oil in there?....
Nemo
PostPosted: 23:56 - 17 Jul 2010    Post subject: Should there be oil in there?.... Reply with quote
I have an '03 Suzuki GX 125, wish is pretty identical to the GS 125.
Basically the starter motor has packed up, well, it makes the noise but doesn't turn anything (best I can describe it).
My mate thought it might just be carbon brushes or something silly and has a spare one I can have any way.
Went to take it out, but it's not as simple as pull it out, so start to unbolt the casing where the generator magnito thing sits, and oil starts dripping out.
Just wondering why or how there would be oil in there. If the seal has gone, would I have to take out the whole engine and strip it just to change that seal?
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
stonesie
PostPosted: 00:06 - 18 Jul 2010    Post subject: Reply with quote
You should be able to unbolt the magneto plate and remove it and see the oil seal beneath, a careful hand should be able to drill a small hole in it without damaging the area that the seal runs on.
Next you screw a small self tapping screw into the oil seal and yank the bugger out with pliers, 2 opposite screws may be required.... Install a new one with a suitably sized deep socket (to drive it on the outer rim) then build it all back up and jobs a good-un Thumbs Up
stuartadair
PostPosted: 21:13 - 19 Jul 2010    Post subject: Reply with quote
Is this engine similar to the CG125? From what you describe it sounds similar and I know exactly what you mean because I panicked when I first saw oil around the magnito. If I remember right the cover is quite tight as its magnetised and the oil is fed through a small hole under the magnito. Its the same on all the Chinese CG derived engines (FM series) too.
I've taken a few of these engines to bits and they all have the same feature, oil in the magnito housing.
Nemo
PostPosted: 23:29 - 19 Jul 2010    Post subject: Reply with quote
So it's nothing to worry about?
I need to somehow get the starter motor out and it's not as simple as "tug" it out (I was hoping it would be).
So I don't know whether taking this casing off would help.
Would this mean that I will have to drain the oil out to do it?
Thanks for the advice, put my mind at rest, sounds depressing but never had a 4-stroke before Thumbs Down
Nemo
PostPosted: 00:00 - 20 Jul 2010    Post subject: Reply with quote
rob yarrr wrote:
i toke the magneto off my cg and there was a small amount of oil that came out,to lube the flywheel gear
put it all back together and it was fine,you've probs done the same
I didn't take the magneto off though, just started to undo the case and oil started dripping out, not gushing, but dripping.
Might take the case fully off and see what happens, need to work out how to get the starter motor out first though.
oriel dave
PostPosted: 00:31 - 20 Jul 2010    Post subject: Reply with quote
As said I don't think you need to worry about a bit of oil dripping out, but are you sure you need to be taking the engine casing off? Isn't the starter motor just bolted onto the front?
Also are you sure the starter motor is your problem? Does it bump start?
Europe Trip 2009
SnowTigeress
PostPosted: 01:12 - 20 Jul 2010    Post subject: Reply with quote
have you got the bible for your bike?
15 quid answers lots of silly questions..
as im finding out building my first project my cb125 has a dry magnito,where some have wet ones
Real bikers build their own Renovated and Riding a 1986 Honda CB125TD-C called the Pup. Full Licence
13/09/2012, 1994 Moto Guzzi 750 Strada
Can-Do Girl that does spanners TOO!
TheSmiler: binning it is better than going around a roundabout the wrong way
PostPosted: 08:31 - 20 Jul 2010    Post subject: Reply with quote
Lol I'm said friend.
The starter is held on by 2 bolts on one side and the actual end of the starter is hidden near the magneto/flywheel.
I started taking the engine casing off on the magneto side and oil started running out.. So I tightened it back up.
Probably check it at weekend, but it's not broken atm...
Also nemo, engine doesn't look like the gs one. Look at the en125 engine
stuartadair
PostPosted: 08:37 - 20 Jul 2010    Post subject: Reply with quote
Hi,
Its normal for quite a lot of oil to come out as the drain hole is quite low down on the engine. I ended up draining all of the oil out
Nemo
PostPosted: 12:01 - 20 Jul 2010    Post subject: Reply with quote
You can use gs125 parts on the en, in which case I can use them on mine.
fiery tupp
PostPosted: 12:22 - 20 Jul 2010    Post subject: Reply with quote
If its the same as GS no need to take flywheel cover off just 2 bolts & cable to remove .
If you can't fix it with a hammer , use your head .
PostPosted: 15:52 - 20 Jul 2010    Post subject: Reply with quote
There was 2 bolts, and a cable on top, but it was stuck in there solid!
Thought there may be a bolt under the engine cover.
fiery tupp
PostPosted: 17:02 - 20 Jul 2010    Post subject: Reply with quote
Not on the GS ,...... But there may well be on GX , I said "If its like the GS just cable & 2 bolts " the same as my GZ ...Same manual as GS ,GN, DR, ..125
The last post was made 16 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.72 - MySQL Queries: 16 - Page Size: 89.69 Kb
