Lifan LF 125 - j Eletrick problem
hughesdesigns...
PostPosted: 16:02 - 20 Jul 2010    Post subject: Lifan LF 125 - j Eletrick problem Reply with quote
My otherhalf has started riding an got her self a cheap 125 (chinese) its the LF 125-j it has a strange problem with the techometre, the rev counter, fuel gage and gear display dasnt work when the engin is running or in neutral.
now the strange thing is if the engine is off in gear and the ignition is on it all works but only if i try an start the bike while it is in gear via the start button (Clutch out) . and it only stays all active if i hold the switch in i know this because you see the display light up with the gear you are in and you see the fuel needle rise up obviously the rev counter does not move as the engine is not running.
so any ideas on this no brainer?
Honda CG 125
Alexio
PostPosted: 16:10 - 20 Jul 2010    Post subject: Reply with quote
I had a very similar bike (was also an LF125) and it had a few weird electrical problems.
However, I ultimately solved them with copious amounts of WD40.
hughesdesigns...
PostPosted: 16:15 - 20 Jul 2010    Post subject: Reply with quote
WD40 ? o..k explain haha?
Honda CG 125
Alexio
PostPosted: 16:27 - 20 Jul 2010    Post subject: Reply with quote
If there's an electrical short somewhere, it gets in there and leaves a protective layer of silicone in between I believe. Just don't get it on your tires.
If this doesn't work, you'll have to pull out all the wires to try and trace the problem.
hughesdesigns...
PostPosted: 16:30 - 20 Jul 2010    Post subject: Reply with quote
hmm ok i have been tryong to find a diagram of the eletrics on line but cvant seem to find it anyware , i want to be sure that all the wireing is ok and as goes for the wireing in the clocks because there so many different connections going in placess that baffle me for such a simple bike i have a cg an there must be twice as many cables on the lifan than that
Honda CG 125
MaybeGuy
PostPosted: 16:43 - 20 Jul 2010    Post subject: Reply with quote
if you're anywhere near plymouth/cornwall ive got one you can have if you collect it. All complete apart from the fairings. Clocks show about 1500 but its done about 11k
edit: just noticed yours is different. Mines an lf125 30
hughesdesigns...
PostPosted: 16:44 - 20 Jul 2010    Post subject: Reply with quote
im in plymouth yes where are you that would be fantastic
Honda CG 125
Alexio
PostPosted: 16:48 - 20 Jul 2010    Post subject: Reply with quote
I'm pretty sure that's the one I had. You know, I almost miss it.
hughesdesigns...
PostPosted: 16:49 - 20 Jul 2010    Post subject: Reply with quote
LF 125 30 has simeler parts according to the supplier i talk to
Honda CG 125
MaybeGuy
PostPosted: 16:53 - 20 Jul 2010    Post subject: Reply with quote
its been sat since 2007 on the driveway, but it runs if you fuel it up. Frames snapped on one of the crossbars and its an 06 plate. All electrics and stuff there.
You'll need a van in case you hadnt realised.
Ill just get onto the mother and make sure it doesnt get thrown in the skip if you want it, as thats what would have happened in the next couple of days
hughesdesigns...
PostPosted: 16:55 - 20 Jul 2010    Post subject: Reply with quote
yeah keep hold of it, where are you to ? PM me with details an i wil contact you
Honda CG 125
MaybeGuy
PostPosted: 16:57 - 20 Jul 2010    Post subject: Reply with quote
halfway between saltash and callington. Pm me a number and ill sort something out. Cant at the mo cos im on the mobile
The last post was made 16 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.01 - MySQL Queries: 16 - Page Size: 77.81 Kb
