Kawasaki ZZR600D Project
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3
jessie61271
PostPosted: 10:45 - 18 Jun 2010    Post subject: Reply with quote
My - you have had a busy week off! Nice one, looking good
Nice photoshop job, graphics really trick it up
See ya next week
unspec
PostPosted: 21:01 - 18 Jun 2010    Post subject: Reply with quote
I had to take a day off from the bikes as it was the g/f's birthday. Smile
So, back to work and it's oil change time. And what a PITA it is on the ZZR, you have to not only detach the oil cooler, but also part undo the frame that it is mounted on just to get to the filter. Who the hell designs this stuff?
Anyway, this is what it looks like when you've got everything out of the way.
https://homepage.mac.com/jrsanderson/images/zzr600/oilcooleroff.jpg
Got the oil filter changed and refilled with some semi-synthetic 10w-40. Thumbs Up
Then I decided to take a few pictures of her:
https://homepage.mac.com/jrsanderson/images/zzr600/nakedzzr1.jpg
https://homepage.mac.com/jrsanderson/images/zzr600/nakedzzr2.jpg
Now although I was just going to stick getting it through the MOT, I fancied doing something to make it a little faster.
I knew for sure of there was one thing that can make a Kawasaki go faster, it's green plastic. Very Happy
https://homepage.mac.com/jrsanderson/images/zzr600/gofasterplastic.jpg
I popped into a local bike breakers and this was for the taking - £200 all in. I decided there and then I wanted it. The belly pan has a burnt bit where the hot oil of the exploding engine cooked it a little but apart from that it's in fair condition.
And this is what the front looks like fitted.
https://homepage.mac.com/jrsanderson/images/zzr600/frontfairingon.jpg
Next, the rest of the fairings....
Grimnir
PostPosted: 13:11 - 19 Jun 2010    Post subject: Reply with quote
Like the new panels! Thumbs Up
Whenever you take the oil filter off, it will drip on the collector and stink like a bastid when you start it up. Might not be such a problem for you as it looks like you have plenty more to do first. Keep the updates coming...
unspec
PostPosted: 20:08 - 19 Jun 2010    Post subject: Reply with quote
Slow progress today.
I spent a good 2 1/2 hours getting the bolts out that hold the sidestand cutout switch in. They were a real bitch (and bent slightly!) but finally I got them out. When I put in new straight bolts, the sidestand plate lined up with the cutout and fixed it. Smile
I also replaced this, with another unit from the same bike that provided my new panels.
https://homepage.mac.com/jrsanderson/images/zzr600/bentgearselector.jpg
Yes, the gear selector was properly bent out of shape. The new one was a straight swap and worked perfectly. Thumbs Up
Finally I put all the panels onto the bike to test the fitting and work out which bolts I'm missing. Here is what it looks like, obviously I have yet to swap the tanks.
https://homepage.mac.com/jrsanderson/images/zzr600/testfitright.jpg
https://homepage.mac.com/jrsanderson/images/zzr600/testfitleft.jpg
Phew!
teabag
PostPosted: 12:41 - 20 Jun 2010    Post subject: Reply with quote
From my vague recollections the rear caliper looks very similar to the one I had on my GSX600F (the original teapot one). These had the torque reaction arm above the swing arm.
NS125R = 2 years > GSX600F = 7 years > XR125L = 3.5 years > SV650S........and a Citroen Synergie HDI for the kids.
unspec
PostPosted: 20:00 - 26 Jun 2010    Post subject: Reply with quote
Short update.
Replaced the number plate light, adjusted the rear brake like switch, bled the front brakes, bled the back brakes, bled the front brakes again, cleaned the left and and bled the front brakes again - they really are shit.
Tank is on, stainless steel bolts were used and I think it is just about ready for the MOT!
https://homepage.mac.com/jrsanderson/images/zzr600/motreadyright.jpg
https://homepage.mac.com/jrsanderson/images/zzr600/motreadyleft.jpg
She scrubs up pretty well for an old bird!
qarka
PostPosted: 21:21 - 26 Jun 2010    Post subject: Reply with quote
Drooling
Grimnir
PostPosted: 22:05 - 26 Jun 2010    Post subject: Reply with quote
Looking good - keep the updates & pics coming Very Happy
deleted111
PostPosted: 16:40 - 27 Jun 2010    Post subject: Reply with quote
Been following this for quite a while now,
really liking the look of it with the green bodywork Thumbs Up
I doubt I'd ever have the patience for something like this, good work mate!
unspec
PostPosted: 18:55 - 15 Jul 2010    Post subject: Reply with quote
Been quiet for a while.
Bike went in for the MOT...and failed.
Some silly stuff I should have sorted with the lights and bars touching the tank at full lock but there was one significant item, the brakes.
Those damn tokico calipers just cant seem to get and feel. So I hunted on ebay and bagged myself a m/c and front caliper set for a CBR900RR for just £33 Thumbs Up
Here is a caliper.
https://homepage.mac.com/jrsanderson/images/zzr600/nissins.jpg
The Honda uses M8 bolts but the holes in the fork mounting points are for M10s. So, I fabricated some sleeves by getting some 10mm steel tube from B&Q with 1mm walls and cut them down to size.
https://homepage.mac.com/jrsanderson/images/zzr600/sleeves.jpg
I then used some M8 bolts and used a washer to position the caliper correctly relating to the disc and another washers to spread the load of the head of the bolt.
https://homepage.mac.com/jrsanderson/images/zzr600/newcaliperbolts.jpg
I also had to do a bit of filing on the caliper to stop the discs from fouling on them and a little was needed of the mounting points on the forks. However, with that done it was a good fit.
https://homepage.mac.com/jrsanderson/images/zzr600/nissinsfitted.jpg
I didn't stop there and decided that I'd use that master cylinder as well just to complete the system. It wasn't too tricky to mount.
https://homepage.mac.com/jrsanderson/images/zzr600/newmcfitted.jpg
I put it back into the garage on a retest and it passed Very Happy
However, disaster was to strike not even 5 minutes after leaving the garage!
While riding the bike my clutch failed!
After getting it home via the RAC, I found that the (bodged) cable was fine but the arm it pulls had slipped down, indeed I could almost pull the thing out of the clutch cover.
Draining the engine and taking off the clutch cover and the clutch actuator arm was mine. I think it is safe to say it is fucked.
https://homepage.mac.com/jrsanderson/images/zzr600/clutchactuatordamage1.jpg
https://homepage.mac.com/jrsanderson/images/zzr600/clutchactuatordamage2.jpg
So, I've got a replacement arm on order along with a new gasket (there was horrible instant gasket used before), new sump plug and crush washer (it was leaking a little) and clutch cable (the other one was bodged to tighten it up even further resulting in a very stiff clutch.
So the wait begins. Hopefully that is all that is required and I don't have to rebuild the clutch. I'd like to avoid that if possible.
unspec
PostPosted: 23:41 - 15 Jul 2010    Post subject: Reply with quote
Oh yes, almost forgot.
The bike has a lovely set of Angel STs as the old rubber was cracking and ruined.
unspec
PostPosted: 11:49 - 17 Jul 2010    Post subject: Reply with quote
All the parts arrived today, so I'll be working on the bike this weekend Very Happy
unspec
PostPosted: 19:42 - 18 Jul 2010    Post subject: Reply with quote
So my parts arrived Smile
https://homepage.mac.com/jrsanderson/images/zzr600/newbits.jpg
I drained the oil out of the engine and took the clutch cover off, it took a while to get rid of the horrible instant gasket stuff - yuck!
This is it all cleaned up.
https://homepage.mac.com/jrsanderson/images/zzr600/clutchcover.jpg
https://homepage.mac.com/jrsanderson/images/zzr600/cleanedclutch.jpg
I installed a new clutch cable Smile
https://homepage.mac.com/jrsanderson/images/zzr600/clutchcablelower.jpg
https://homepage.mac.com/jrsanderson/images/zzr600/clutchcableupper.jpg
And here is the bodge the previous owner did to tension the old cable.
https://homepage.mac.com/jrsanderson/images/zzr600/oldclutchbodge.jpg
I put everything together and made the following observations.
1. Clutch now works but only just, I think the plates are very worn. I can't adjust the cable any further - I suspect this why they did that bodge on the cable in the first place. The only fix for this is new plates I think , so I'll have to get a rebuild kit.
Still at least the clutch action is really nice and smooth now, uline the previous thing that was almost ratchet-like the way the cable felt.
2. I have a small oil leak from a crack at the sump plug Mad I will have to fix this somehow. Liquid metal? JB Weld? It's not under pressure so I just need something that will cope with the high temperatures.
3. look at the difference in the actuator arms!
https://homepage.mac.com/jrsanderson/images/zzr600/newclutchactuator.jpg
Back to wemoto.com I go....
woll
PostPosted: 20:23 - 18 Jul 2010    Post subject: Reply with quote
If it was me i'd get the sump welded/replace the sump it it was cracked.
Bikes looking good mate Thumbs Up
unspec
PostPosted: 22:13 - 18 Jul 2010    Post subject: Reply with quote
You're right of course, but I just want something cheap and quick for the moment.
Gazdaman
I did a trackday!!!
PostPosted: 09:07 - 19 Jul 2010    Post subject: Reply with quote
Liquid metal will do it for the time being, but really you need to get it pretty damn clean to be able to get it to go off nicely.
As above, I'd be looking to get it welded/replaced.
The difficulty of that depends if the crank cases split vertically or horizontally. Still a pain in t' arse.
Clutch thing looks good.
Gaz
unspec
PostPosted: 23:08 - 22 Jul 2010    Post subject: Reply with quote
No real news, just to say my EBC clutch rebuild kit arrived today.
I'll fit it at the weekend. Thumbs Up
unspec
PostPosted: 21:31 - 23 Jul 2010    Post subject: Reply with quote
First thing was first I drained the oil out of a (still quite warm bike) and took all the clutch parts out. It was actually a lot simpler than I thought.
And here is the empty clutch!
https://homepage.mac.com/jrsanderson/images/zzr600/emptyclutch.jpg
I purchased an EBC race clutch rebuild kit. Here is everything out and prepared (I've not soaked the friction plates yet). It has kevlar friction plates, new steels and uprated springs. Thumbs Up
https://homepage.mac.com/jrsanderson/images/zzr600/clutchout.jpg
Here are the old plates. I'm not really experienced enough to know if they are fine or have had it.
https://homepage.mac.com/jrsanderson/images/zzr600/oldfrictionplates.jpg
But here are the fresh news ones for comparison.
https://homepage.mac.com/jrsanderson/images/zzr600/newfrictionplates.jpg
I was advised to check the pushrod bearing, which seems to be in excellent condition.
https://homepage.mac.com/jrsanderson/images/zzr600/pushrodbearing.jpg
And the pushrod itself also looks really good.
https://homepage.mac.com/jrsanderson/images/zzr600/pushrod.jpg
And that's it so far - apologies if this stuff is a bit boring but I've never done anything like this before so thought it would be good for me to document it. Smile
unspec
PostPosted: 23:11 - 23 Jul 2010    Post subject: Reply with quote
Embarassed
I should have checked the torque of the bolts, I sheared the head of the second one right off.
Apart from feeling like a right muppet, what's the best tool for the job?
If I can get a pilot hole in, would these do the job?
https://www.screwfix.com/prods/18643/Drill-Bits/Specialist-Drill-Bits/Screw-Extractor-Set?cm_mmc=GoogleBase-_-Datafeed-_-Drill%20Bits-_-Screw%20Extractor%20Set#
mad4it028
PostPosted: 23:16 - 23 Jul 2010    Post subject: Reply with quote
if you just snapped the head off remove all other bolts then the cover or whatever you were bolting up and wind the rest of the bolt out with grips Thumbs Up
unspec
PostPosted: 07:45 - 24 Jul 2010    Post subject: Reply with quote
It's recessed, there is nothing sticking out. I'm thinking I may have to drill it.
unspec
PostPosted: 11:53 - 24 Jul 2010    Post subject: Reply with quote
Dance!
https://homepage.mac.com/jrsanderson/images/zzr600/boltfinallyout.jpg
Gazdaman
I did a trackday!!!
PostPosted: 14:55 - 24 Jul 2010    Post subject: Reply with quote
unspec wrote:
Nice one! First time I've ever heard an actual success story for one of those!
Gaz
unspec
PostPosted: 17:47 - 24 Jul 2010    Post subject: Reply with quote
Gaz
I managed to drill pretty much spot on in the centre with a hardened small bit then work up to 5mm. Once there was a decent hole down the middle of the bolt, I used the extractor very carefully!
I was soon greeted with the wonderous sight of the end of the bolt coming out.
Actually I then finished the clutch work, so it's all back in with the new springs, apologies for the lack of pictures!
I'll test it tomorrow as I've been drinking beer this afternoon. Smile
unspec
PostPosted: 20:03 - 16 Sep 2010    Post subject: Reply with quote
Small update, it's not project related as I'm going to just run the thing until the summer now (I will probably start a Thundercat project page sometime).
Regulator/rectifier failed so I had to replace it.
It was running very hot, and was making a seriously nasty acrid smell.
https://homepage.mac.com/jrsanderson/images/zzr600/oldregrec.jpg
Here is the new one for comparison.
https://homepage.mac.com/jrsanderson/images/zzr600/newregrec.jpg
The ZZR couldn't charge itself before so I'm hoping it's fixed that as well!
The last post was made 16 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 16 - Page Size: 138.42 Kb
