Quick question about tyre pressures.
MementoMori
PostPosted: 14:04 - 30 Jul 2010    Post subject: Quick question about tyre pressures. Reply with quote
Hi there,
I have a CBR929RR Fireblade and run pressures of 36 on the front and 42 on the back. After a few months, the back's usually lost about 2psi but the front's always down at around 20 and it obviously feels like ass to ride.
Just wondered why the front goes so low over... .say.... 2/3 months whereas the back is fine. It did it on the old tyres and it's doing it on the new ones too so I ruled out a slow puncture.
Is that about normal for bikes? Just not experienced this quirk (hopefully not a problematic one) before.
Thanks very much.
Steph.
The tiger who came for a pint
tatters
Exxon Valdez
PostPosted: 14:12 - 30 Jul 2010    Post subject: Reply with quote
Air naturaly leaks out from between the bead and the rim of the wheel as well as the rubber compound its self, having corrosion on wheel rim can make this alot worst l,ve had to use bead sealant (black rubber glue) to leaking rims in the past when tyres have gone flat in space of a few days.
PostPosted: 14:31 - 30 Jul 2010    Post subject: Reply with quote
I'd be more concerned about only checking tyre pressures every 2-3 months Smile
tatters
Exxon Valdez
PostPosted: 14:51 - 30 Jul 2010    Post subject: Reply with quote
If its only going down over a few months l would not worry about it, my BMW is fitted with one of the earlyest tubeless spoke wheels and they leak down over about 1 month.
Rowey
PostPosted: 15:22 - 30 Jul 2010    Post subject: Reply with quote
I'd say either get a new valve fitted or check for corrosion around the bead.
My girfriends vespa kept loosing pressure on the back wheel. Turned out water had been sitting in the bead and got between the paint and metal causing it to flake off and ruin the seal.
I quick wire brush to get off the loose paint and corrosion then some bead sealant.
ZX6R C6F.
PostPosted: 15:25 - 30 Jul 2010    Post subject: Reply with quote
I only check mine when it feels different, I can normally tell when the front is 5psi or more down, the rear is harder to tell.
MementoMori
PostPosted: 21:14 - 31 Jul 2010    Post subject: Reply with quote
Thanks for the responses, this answers my question.
Cheers guys. Smile
ws4936
PostPosted: 00:28 - 01 Aug 2010    Post subject: Reply with quote
What's air pressure???
If everything seems under control, you're just not going fast enough.
The last post was made 16 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.13 - MySQL Queries: 16 - Page Size: 59.17 Kb
