Author |
mario |
mario Scooby Slapper
Posted: 15:10 - 12 Jul 2004 Post subject: Gilera DNA50??? |
Hey,
I have had problems with my DNA but can't find whats up with it?
My temperature display reads normal then goes to 100-120oC after about 5mins?
I've spent lots of time today looking at it, filled coolant tank went out for a while, temp was 120 but it wasn't over-flowing or anything like that?
Anyone know what could be up with it and how I could fix it???
Many Thanks
Mark |
Back to top |
Lee_367 |
Lee_367 Brolly Dolly
Back to top |
FragReaper |
FragReaper Two Stroke Sniffer
Back to top |
conpants |
conpants Spanner Monkey
Back to top |
mario |
Back to top |
phill.c |
phill.c Traffic Copper
Back to top |
bikedudextrm |
bikedudextrm Traffic Copper
Back to top |
Dup |
Dup Nova Slayer
Posted: 20:02 - 20 Jul 2004 Post subject: |
NEVERMIND! 50's are different
My 125's cooling system went tits up recently.
Just by your right leg there is the thermostat. The top half of it is black with a big tube coming out the top. Get a hammer with a bit of wood on the thermostat and give it a light but authroative tap. Chances are that might be stuck.
On the same side a little lower and further back is a grey metal engine casing with two tubes. This is basically your pump.
To drain the system get a bucket and drain the bottom tube. Now remove that plastic side with the two tubes and start the bike up. If the little fan (called imi-something) spins up, your fine, put it all back together. If not, remove the casing. Inside there is a bakelite flywheel type thing. If you can turn that and the fan thing turns, the motor has probably gone.
If you really want to know if it's a faulty reading, go out and get it to flashing point on the dash then put your hand on the radiator. If it's hot, its fine, if not you have a problem.
Open up the false tank and open up the coolant (when its cool! That shit gets hot and pressure spurts it out when it's hot) and then start the bike. If it's circulating properly, you should see a little jet of coolant.
Thats all i can suggest from my experience of my 125. I hope it's the same kind of system. I'll look into it now but it shouldn't be that different really. Other than this it's more than likely shitty Italian electrics. Then just run the hell away! |
Back to top |
Biker_Dene |
Biker_Dene Crazy Courier
Back to top |
The last post was made 19 years, 287 days ago. Instead of replying here, would creating a new thread be more useful? |
