Blu Ray drive not working.
PostPosted: 00:41 - 12 Aug 2010    Post subject: Blu Ray drive not working. Reply with quote
I have a new build with a Asus P6X58D-E MOBO with a blu ray and a Sata drive I'm fairly certain when I first built it, both optical drives worked fine. Now the blu ray drive doesn't, It shows up in the raid controller but not in Windows, the DVD does but the blu ray doesn't there is power going to it, and I have tried swapping the data leads, no joy. I changed the raid controller from RAID to AHCI nothing. I also plugged the drive in using a USB - SATA cable which worked.
Any ideas?
TomCB
PostPosted: 02:12 - 12 Aug 2010    Post subject: Reply with quote
is it disabled in device manager?
Faldo: "Classic BCF. A thread about sky diving is NSFW on post #2."
CaNsA
PostPosted: 07:04 - 12 Aug 2010    Post subject: Reply with quote
Chris, no my mom didnt mention anything Laughing
try this dude, i had a similar problem a few weeks back and this solved it.
regedit (export your whole registry just in case innit)
then goto:-
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters....
Reboot and have a look
hth
PostPosted: 09:33 - 12 Aug 2010    Post subject: Reply with quote
then goto:-
hth
Will give it a try tonight, Cheers.
Neorion
PostPosted: 11:05 - 12 Aug 2010    Post subject: Reply with quote
have you installed any new burning software recently?
If so remove it and reboot after trying the upper and lower filters
VFR FI 2000- Shiney Red Thing
"some things man was never meant to know, for everything else there's Google"
PostPosted: 18:24 - 12 Aug 2010    Post subject: Reply with quote
No but I did install daemon tools which may be the cause.
PostPosted: 18:31 - 12 Aug 2010    Post subject: Reply with quote
Did that there was no lower filter only upper filter, rebooted and still no drive.
CaNsA
PostPosted: 18:34 - 12 Aug 2010    Post subject: Reply with quote
Is there another computer you can try it in?
I had a drive die on me, showed up in the bios but not in windows, nor in some-one elses rig.
Onboard sata or a sata card?
PostPosted: 22:46 - 12 Aug 2010    Post subject: Reply with quote
Onboard SATA, If I put it through a SATA/USB doodah it works fine on this PC.
PostPosted: 00:06 - 13 Aug 2010    Post subject: Reply with quote
Fixed it, connected it to another SATA port I didn't know I had Laughing
CaNsA
PostPosted: 07:02 - 13 Aug 2010    Post subject: Reply with quote
LOLZ
https://www.resources4russian.co.uk/essay/winner-win.jpg
The last post was made 16 years, 29 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.56 - MySQL Queries: 17 - Page Size: 75.51 Kb
