Shared Storage Solutions
Fawbish
PostPosted: 10:02 - 25 Aug 2010    Post subject: Shared Storage Solutions Reply with quote
Wassup guys.
Right, I'm looking for a solution that is fairly simple, fairly cheap.
It's not a problem as such, but I'd quite like to be able to store a lot of my stuff/media on a seperate device. Theres me and my mate living together and both have a laptop, theres an x-box and a fat 42" TV.
Is there a cheap/easyish solution without buying a server and learning how to set one up?
I'd like to do it wirelessly and even have it automated to use the external storage first, so the laptops also run quicker.
Is it simply a case of looking for the cheapest wirelessly enabled storage? Any direct suggestions with experience with anything (or a solution that you know of that matches the criterion) would be great.
I'm not particularly down with networking above setting up a router and streaming media to the xbox Embarassed But dont particularly have time at the moment to set aside and learn - though want to eventually.
Cheers people.
PostPosted: 10:09 - 25 Aug 2010    Post subject: Reply with quote
You can get a network drive but the speeds over wireless aren't brilliant HD content is a definate no no and unless you are have an N spec wireless connection or very good signal normal video can be a bit crap.
PostPosted: 10:15 - 25 Aug 2010    Post subject: Reply with quote
I've an old Buffalo LANDisk plugged into my router, it just shows up as a networked hard drive on all my PCs.
Trying to find an equivalent, there's this, but I'm sure something could be sourced more cheaply :-
https://www.amazon.co.uk/152834-Iomega-Network-USB2-0-Silver/dp/B003D0R69C/ref=sr_1_1?ie=UTF8&s=computers&qid=1282727683&sr=8-1
Fawbish
PostPosted: 10:21 - 25 Aug 2010    Post subject: Reply with quote
We have an N-wireless router, fairly top of the range but nothing super special I dont believe.
Shaggy, food for thought. I could simply attach that to my router and then transfer files/set my laptop to immediately save data to that HDD? Sounds like its worth a gander. I've seen a 1.5TB storage unit for 75 quid...hmm. Thinking
PostPosted: 10:58 - 25 Aug 2010    Post subject: Reply with quote
Yup, it appears as a shared directory, so I've got it mapped as the L: drive on all my PCs. It does have a manager proggy with it so you can set up more user shared areas, but since there's just the two of us, I leave it as one big repository of crap. Mine's also got a couple of USB ports which apparently can be used for hooking up more storage and/or attaching a printer to, but I've not used that facility.
It's really a mini pc running a bespoke Linux setup, some people like to flash it and run it as a proper server :-
https://buffalo.nas-central.org/wiki/Main_Page
herulach
PostPosted: 22:47 - 25 Aug 2010    Post subject: Reply with quote
Something like shaggy says would be ideal, don't worry about wireless, so long as theres space to connect directly to your router. And ideally run a cable to the xbox, I imagine thats where you stream most HD stuff to?
This buffallo one links in nicely with windows & xbox, integrates with your iTunes library and has a bittorrent client.
If you want something upgradeable this netgear one comes with a free 500gb hdd, and should do more or less the same stuff but easier to back up.
YBR 125>FZS600
Tarmacsurfer
PostPosted: 00:49 - 26 Aug 2010    Post subject: Reply with quote
I wouldn't touch the Stora, not great hardware to say the least.
I'm immortal. Well, so far.
_Will_
PostPosted: 10:20 - 26 Aug 2010    Post subject: Reply with quote
One of these, USB wireless n hub
Connect to external hd, bingo!
Also let's you plug in pen drives, printers etc, should do the trick.
Suffering Bike Withdrawal.
The last post was made 16 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.54 - MySQL Queries: 16 - Page Size: 63.3 Kb
