sprockets???
oatesmx
PostPosted: 20:40 - 20 Oct 2010    Post subject: sprockets??? Reply with quote
hey guys, just wanted to make sure that i was coorect in thinking that the bigger the rear sprocket and the smaller the front sprocket, the easier it would be in getting that front wheel into the sky? and does it really matter, rite now im running 12on the front to 50 on the back, but i'm thinking of changing to 11-56, basically i just want to wheelie and at the moment it is a bitch to get the front wheel up, any tips? and would changing my gearing make a BIG difference or is it not worth it? cheers
if it doesn't smoke, it's a joke... 2stroke for life bitch!!!
PostPosted: 21:01 - 20 Oct 2010    Post subject: Reply with quote
You are right, but make the gearing too low and you will just land up running out of revs immediately as the front wheel comes up.
PostPosted: 21:02 - 20 Oct 2010    Post subject: Reply with quote
Yes, it would probably flip over backwards on that gearing and you could pull away smoothly in third.
Remember it will also drop your top speed. You're talking about a radically different gearing there though. Almost certainly WAY too much
12:50 = 1:4.167
11:56 = 1:5.090
So that will drop your top speed by 22%
Dropping a single tooth on the front by itself would decrease your top speed by 9%.
Adding two on the rear by itself would decrease it by 4%.
A little bit at a time is the way. I'd try dropping one tooth on the front to start with.
The last post was made 15 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.67 - MySQL Queries: 16 - Page Size: 38.55 Kb
