Spraying a black panel black
Quickly
PostPosted: 12:21 - 29 Oct 2010    Post subject: Spraying a black panel black Reply with quote
I've got a set of panels I want to spray black. They already are that colour but a bit faded, scratched, scruffy. Will I still need to sand and prime then, or could I get away with sanding and no primer (I assume I need to sand them so the paint sticks cleanly).
Syris the Indomitable
PostPosted: 13:35 - 29 Oct 2010    Post subject: Reply with quote
That's what I would do and just fill in any deep scratches with car body filler, sand till smooth.
Rub down with 80 grit wet and dry.
Then rub down with 1200 grit wet and dry paper until smooth.
Shake the can vigorously for two minutes.
Holding the spray can approximately 25cm away from the surface to be painted, apply a 2 to 3 coats of paint at 20 -30 minute intervals.
Allow the paintwork 24 hours to dry then rub it down with 1200 grit wet and dry paper. It should lose its gloss appearance and take on a dull, matt finish. Clean with warm, soapy water, rinse and dry.
Apply clear lacquer.
https://www.youtube.com/watch?v=xG4ex1Q4Xak
In Greek mythology Ichor is what immortals have in the place of blood
Those that mind, don't matter...Those that matter, don't mind. Do you agree with this?
PostPosted: 14:42 - 29 Oct 2010    Post subject: Reply with quote
Just watch out that lacquer can take a long time to fully cure. Go very light with it - better to do a light coat, wait a week, then do another light coat than slap on a thick coat that'll wrinkle and pick up thumbprints for weeks.
Teflon-Mike
tl;dr
PostPosted: 17:57 - 29 Oct 2010    Post subject: Reply with quote
Are the panels original finish or has some-one painted them before?
Personally I'd flat back to plastic, use key or plastic prime then paint.
If you spray-over, there's risk that the paint wont key or will react with paint beneath.
map
Mr Calendar
PostPosted: 14:22 - 01 Nov 2010    Post subject: Reply with quote
I'd say before you paint, either primer of colour, to make sure you wipe over with some solvent based cleaned just to make sure panels clear of any muck and oil.
alan0259
PostPosted: 17:36 - 01 Nov 2010    Post subject: Reply with quote
Don't want to jump on your thread but you might find this useful too.
I recently painted my side panels in Matt Black, the finish is excellent but i'm finding it hard to keep the finish looking good. Obviously lacquer will ruin the Matt effect, is there anything out there like a wax that will help protect the paint but leave the Matt look?
TQ
PostPosted: 17:47 - 01 Nov 2010    Post subject: Reply with quote
I'm fairly sure you can get matt lacquer although a quick google didn't turn anything up.
First Bike :Gilera DNA 50 | Second: Imported 1989 NSR125
Third: 1998 Yamaha XJ600N | Currently: 1999 Yamaha FZS600
map
Mr Calendar
PostPosted: 11:05 - 02 Nov 2010    Post subject: Reply with quote
Really? I suspect your school reports were along the lines of "must try harder".
Entered "lacquer matt" into google and got a few.
Filtering out those for floors/walls and still some left.
Like this one from Screwfix @ £5.50.
https://www.screwfix.com/sfd/i/cat/46/p4780046_l.jpg
The last post was made 15 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.51 - MySQL Queries: 16 - Page Size: 61.37 Kb
