Kawasaki z200 no spark
Justingrantgr...
PostPosted: 15:41 - 30 Oct 2010    Post subject: Kawasaki z200 no spark Reply with quote
Im driving a kawasaki z200 but the bike has stopped sparking ive tried replacing the spark plug. i have checked the cdi unit the pulse generator and the coil. all the bikes wires are carrying the voltage to the right place. so i can not figuer out whats the problem.
rob_scott92
PostPosted: 20:28 - 30 Oct 2010    Post subject: Reply with quote
Do you know if it uses a source coil? Ie. the movement of the engine powers the ignition rather than the battery if you get what i mean???
It was the same on my Gs 125, we changed the ignition system to that of a later model which uses the battery and i assume its still running Thumbs Up
Actually, just read what i wrote. Probably doesn't make much sense Laughing
Do you have a wiring diagram for the bike?
First bike: 1982 Suzuki Gs 125 'The beast MK1' Wink > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p
Ed Case
PostPosted: 20:52 - 30 Oct 2010    Post subject: Reply with quote
I had a Z200 for years, great little bike, as reliable as a water wheel, never let me down. 1= The switch on the RH handlebar not in the "OFF" position is it ? (I know this sounds daft but it's happened).2= Have the ignition 'points' closed up ?. 3= Check the connections from the coil into the wiring loom. 4= Remove the spark plug cap, hold the HT lead 3mm from the head, press the starter and then see if you've got a spark these things dont last forever. 4= The condenser could be 'rubber-ducked', these usually fail when the engine gets hot and then work again when it cools down. Try these tips then come back to us, Regards.
Odie
PostPosted: 16:13 - 31 Oct 2010    Post subject: Re: Kawasaki z200 no spark Reply with quote
I thought that the Z200 was a points ignition system, can remember when they first came out, dont remember the having C.D.I's.
radical
PostPosted: 00:29 - 01 Nov 2010    Post subject: Reply with quote
Check the sidestand switch if fitted.
Ed Case
PostPosted: 17:00 - 02 Nov 2010    Post subject: Reply with quote
None fitted but a good suggestion for more modern bikes !. Thumbs Up
The last post was made 15 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.51 - MySQL Queries: 16 - Page Size: 54.08 Kb
