Im confused! changing gear without using clutch
bugsy46
Village Idiot
PostPosted: 21:03 - 29 Jul 2004    Post subject: Im confused! changing gear without using clutch Reply with quote
Hi I was wondering when you ride a production bike if it is ok to not use your clutch! for example when you watch the gp bikes they change gear without using the clutch thus not losing the revs! is it a matter of getting the revs just right or what? please help!!
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
Demonic69
The Pink Rhino
PostPosted: 21:05 - 29 Jul 2004    Post subject: Reply with quote
The GP bikes will probably have quickshifters. But changing without clutch is dead easy and knocks seconds off a 1/4 mile time.
Changing up: Put pressure on the gear lever, dip the throttle and the bike will probably change on it's own.
Down: Same again but blip the throttle instead.
Back on a Blade. Just feels so right.
Mr C
PostPosted: 21:23 - 29 Jul 2004    Post subject: Reply with quote
not advised to change down without using the clutch
it can be done but can damage everything while you get it right
changing up is exactly as D says
although if it could shave SECONDS off quarter times I'd be running 3's Laughing Laughing
187.3bhp = 201mph
Demonic69
The Pink Rhino
PostPosted: 21:24 - 29 Jul 2004    Post subject: Reply with quote
I knocked a good second or 2 off Razz Was on the 400 and still got over 15 but Razz
Claud 14.7 to 1
PostPosted: 21:30 - 29 Jul 2004    Post subject: Reply with quote
Do you guys/gals use clutchless up-shifting all the time then? Or just when going full on?
I have never used clutchless shifting.
On Moto GP bikes, the the rpm cuts the right ammount, automatically, when they up-shift so they can just use W.O.T when up-shifting Cool .
Demonic69
The Pink Rhino
PostPosted: 21:34 - 29 Jul 2004    Post subject: Reply with quote
I use it most of the time now. generally have to concentrate when I try to use the clutch
Mr C
PostPosted: 21:36 - 29 Jul 2004    Post subject: Reply with quote
you can shift with a WOT on any bike - you have to fit a Quickshifter as D said
it's basically just a switch that attaches to the gear lever, when it senses enough pressure or movement it sends a signal to a kill box which interrupts either fuel or ignition just long enough to engage the next gear
I only upshift without the clutch at very high rpm, it's a bit jerky low down
I run 10.5s on flyer gearing
187.3bhp = 201mph
Claud 14.7 to 1
PostPosted: 21:40 - 29 Jul 2004    Post subject: Reply with quote
Hehe, it would be the complete opposite for me. I can shift pretty quickely with clutch.
Yer i know, i just thought on the quickshifters that us mere mortals are allowed to buy you wouldn't have the feature of an rpm cut, be it fuel or ignition enduced.
Tis pretty cool. Thumbs Up.
AcIdBuRnZ
PostPosted: 21:50 - 29 Jul 2004    Post subject: Reply with quote
Yeah, you think you are shifting quickly - try it without the clutch and you'll feel the difference Thumbs Up
loply
PostPosted: 22:06 - 29 Jul 2004    Post subject: Reply with quote
How much does a quickshifter cost?
I often shift up on my car without the clutch, just push the lever gently into the next gear and for a second it stays there, then when the RPM matches the gear it pops in of its own accord. Same for going down gears, but its trickier.
kev
I Hump Things
PostPosted: 22:59 - 29 Jul 2004    Post subject: Reply with quote
It tends to bugger up gear boxes on cars doing that.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
Claud 14.7 to 1
PostPosted: 23:37 - 29 Jul 2004    Post subject: Reply with quote
Hehe, yer i'd say... Laughing
What the point anyway, if you practice you can get changing gears in cars, very fast. (much quicker that all that gently move gear stick....) business.
Believe my i've tried...
Mr C
PostPosted: 00:13 - 30 Jul 2004    Post subject: Reply with quote
this IS a quickshifter, all it does it cut the rpm - it doesn't do anything else - it is the ONLY feature it has
maybe you are confusing it with a powershifter or air shifter which physically moves the gear lever, normally actuated by buttons on the handlebars
you can get a basic quickshifter and kill box for about £300
airshifters are more liek a grand and require chargable air bottles and/or onboard compressors
powershifters are pretty new but use linear motors or cheaper versions use solenoids to tug the gearlever up at the same time as they kill the engine
187.3bhp = 201mph
loply
PostPosted: 00:19 - 30 Jul 2004    Post subject: Reply with quote
Are DIY quickshifters feasible, and do they work well if so?
dibbster
PostPosted: 00:26 - 30 Jul 2004    Post subject: Reply with quote
Excuse my ignorance but what is WOT.
I believe the Gp bikes use a slipper clutch for the downshifts.
Clutchless upshifts Thumbs Up Clutchless downshifts - a little more tricky.
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
PostPosted: 00:33 - 30 Jul 2004    Post subject: Reply with quote
WOT = Wide Open Throttle
dibbster
PostPosted: 00:37 - 30 Jul 2004    Post subject: Reply with quote
well its obvious now. Embarassed
Claud 14.7 to 1
Ah i see, ok . You're right. Cheers Thumbs Up
Mr C
PostPosted: 00:58 - 30 Jul 2004    Post subject: Reply with quote
if you are an electronics whizz and can invent a circuit which when actuated will cut power to the injectors or the ignition for a preset time measured in milliseconds and you can make a pressure switch affair to actuate it and mount it on the gear lever then yes
187.3bhp = 201mph
The last post was made 21 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 101.98 Kb
