Reuseable ground anchor?
Ingah
PostPosted: 17:45 - 11 Nov 2010    Post subject: Reuseable ground anchor? Reply with quote
Have previously posted asking about ground anchors, but i've since found out the others in my shared house definitely want to move next year (wasn't bothered either way myself), so i'll be going with them. In the meantime though, i really need a ground anchor as i just don't feel safe with my awesome chain being relegated from decent protection to just making my front wheel reasonably secure (to a mere thick beam of wood).
As i'm too short on money to keep buying a new ground anchor every year (i foresee me moving around a lot over the next few - and my 0% student overdraft makes clever spending now cheaper than recurring smaller spends), i was hoping i could buy one decent one for my Almax, and then re-use it in subsequent houses etc. I know that most ground anchors aren't designed to be removeable, but i have heard of at least one that is (although i forgot what it's called) - apparently the bolts are removable and are covered by the chain when it's in, therefore it should be secure enough. Anyone heard of one or know of something suitable?
Or is it possible to make normal ground anchors removeable by using a different bolt? (but then at least a couple would need to be in such a place that the chain will prevent access to their bolt heads at the very least).
-- Ingah
Bendy
Mrs Sensible
PostPosted: 17:50 - 11 Nov 2010    Post subject: Reply with quote
Water butt full of rubble and concrete with a tube through it for your chain.
Flip
PostPosted: 18:04 - 11 Nov 2010    Post subject: Reply with quote
Get an anchor that sits in the concrete rather than bolted to it and dig it out when you need to move it. (It would be a ball ache though).
Ingah wrote:
I know that most ground anchors aren't designed to be removeable, but i have heard of at least one that is (although i forgot what it's called) - apparently the bolts are removable and are covered by the chain when it's in.
https://www.yanchor.com/BOLT.html Question
FreshAL
Sir Crashalot
PostPosted: 18:22 - 11 Nov 2010    Post subject: Reply with quote
CHR15 wrote:
aquire a wheelie bin.
hole saw two holes in it near the bottom. fit a length of pvc pipe through the holes.
half fill with concrete.
remove wheelie bin wheels.
then refit wheels when you need to move it.
Which works fine till the first mong-tard from the council reports you for criminal damage to a wheely bin or actually tries to move the bin and pulls your bike over.
The Artist
PostPosted: 18:41 - 11 Nov 2010    Post subject: Reply with quote
CHR15 wrote:
this is why i like living in the middle of no where.
No you don't live in the middle of nowhere. You have shit loads of houses around you.
Bloke
PostPosted: 20:02 - 11 Nov 2010    Post subject: Reply with quote
I think the hardie ground anchor is removable. You bolt it into the floor, place the outside cover over it and then chain your bike. The chain stops the thing from being unbolted.
It looks like a round metal disc.
2008 VFR800 VTEC
Gazdaman
I did a trackday!!!
PostPosted: 21:20 - 11 Nov 2010    Post subject: Reply with quote
The ground anchors I've got were £6.40 each, including bolts.
https://cgi.ebay.co.uk/ground-anchor-yellow-cheapest-ebay-/280577030566?pt=UK_Motorcycle_Parts&hash=item4153b1b9a6#ht_500wt_1156
EDIT: Looks like they're slightly more expensive now if you want the bolts too, but still less than £8.
Gaz
Peirre oBollox
PostPosted: 23:03 - 11 Nov 2010    Post subject: Reply with quote
Gaz
looking at that, it would take around 20-30 seconds with a hacksaw to split it along its length Thumbs Down
Gazdaman
I did a trackday!!!
PostPosted: 23:32 - 11 Nov 2010    Post subject: Reply with quote
It'd take longer than that. And any motorcycle protection is a deterrent at best. A decent bolt cropper, or a chisel and hammer would take care of a large percentage of locks.
Get an angle grinder involved and even fewer would survive.
I strongly suspect that would make most if not all thieves move onto another garage. Especially since my garage is right behind my house, and the front is overlooked by 4 houses.
Gaz
swiftb
PostPosted: 23:56 - 11 Nov 2010    Post subject: Reply with quote
https://www.yalesecuritypoint.co.za/PageFiles/169/hr_P820-100-60-1.jpg
Can get this type, bolt the anchor into the floor/wall with normal coach bolts, then the metal cover slips over the whole anchor which is held in place by the padlock, which obvioulsy prevents access to the bolts.
loply
PostPosted: 00:02 - 12 Nov 2010    Post subject: Reply with quote
I bought a run of the mill steel oxford ground anchor and just bolted it to the house using shield anchors.
You might think that somebody could just unbolt it, no?
Ahar! Once you have slotted an Almax chain through the thing, there is not sufficient space to get ANY kind of spanner in to remove the bolts, let alone space for the bolt to come out.
Unlock the chain and slide it out of the anchor and i can simply unbolt the anchor from the wall and take it away...
Karma Thumbs Up
Yamaha SZR660 Caution to the wind, the throttle pinned!
The last post was made 15 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.07 - MySQL Queries: 16 - Page Size: 73.18 Kb
