When you get a new (2nd hand) bike - what do you do to it
Ingah
PostPosted: 23:39 - 27 Dec 2010    Post subject: When you get a new (2nd hand) bike - what do you do to it Reply with quote
When you get a new bike (not talking brand new here. but 2nd hand -or 3rd/4th/5th etc depending on what you tend to buy), what do you tend to do to it on receiving it? Just idle wondering/curious as to what people do to their machines before they consider them "ready".
Might also be interesting to know what sort of machine/usage it is too (for example i suspect perhaps some sports bike riders will put in a power commander in straight away, and perhaps some 2-stroke owners will give it a rebuild straight away if it's not had one recently).
e.g. For my current bike (CB500), i bought it at 14 years old and high(ish) mileage, no service history. And wanting a reliable machine for use as my sole transport/commuter use (this reliable machine never materialised, but hey, it wasn't through lack of effort!) i serviced it very thoroughly ASAP (including valve clearances etc), changed the mismatched old tyres for BT45s, and added throw-over panniers.
If i hadn't needed to spend out a load on constant repairs from the get-go, i would also have uprated the headlamp bulb immediately, changed the mirrors for longer-stem ones, got a braided front hose, replaced the can, replaced the rear shocks with new Hagons and progressive front fork springs. As it is these modifications have had to wait a while and been done later on (the suspension upgrades and exhaust upgrades are still waiting 2 years down the line).
-- Ingah
L4Isoside
PostPosted: 23:49 - 27 Dec 2010    Post subject: Reply with quote
Well, depends on the bikes current condition I suppose.
For my YBR, I did nothing. Still haven't done anything except when my mate had it, changed the tyres! I think it had 1 or 2 previous owners but only about 900mi on it.
For my SV, didn't do anything for a good while. But eventually changed the tyres after I crashed and realised that the current tyres where the originals (10 years old, 6k mi)
For my ninja, replaced a few bolts for stainless, put a tank pad on. Still plan on getting stomp grips and new tyres but not in any rush.
So was "ready" as soon as I got them home and gave it a once over.
dodgydog
PostPosted: 23:52 - 27 Dec 2010    Post subject: Reply with quote
Oil and filters, plugs.
Strip and clean the Brakes.
Chain tension, alignment, lube.
That's about it.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
Clanger
Stirrer
PostPosted: 23:55 - 27 Dec 2010    Post subject: Reply with quote
The usual essentials, tax and insurance...(mini service), adjust suspension to suit my needs then heated grips and possibly change tyres to suit me. Then nowt else really. Concentrate on riding the damn thing...
Seb
PostPosted: 23:57 - 27 Dec 2010    Post subject: Reply with quote
Oil and filters as a priority regardless of when they were last changed. Beyond that I'll check the rest of the consumables out to be sure, coolant is something that is probably wise to change as a precaution, esp in this weather but meh Smile
2010 Triumph 1050 Sprint ST
c_dug
PostPosted: 23:58 - 27 Dec 2010    Post subject: Reply with quote
Get on bike Arrow Ride bike.
That is all.
truslack
PostPosted: 00:15 - 28 Dec 2010    Post subject: Reply with quote
Quite often, spray it black. Laughing
Teflon-Mike
tl;dr
PostPosted: 00:29 - 28 Dec 2010    Post subject: Reply with quote
Not a chop-and-change man.
Each bike's been different.
Unless I've bought them as a fixer-upper though, I've expected them to work, at least well enough to ride home.
Job-List starts being compiled before hard-earned is handed over, noting whats good, bad, or iffy, and haggling over whatever I can!
Ride home tells me more, and the job-list starts getting added to.
Then a basic service at the earliest opportunity oto get an idea of the detail.
Then I prioratise whats most needed and start working down the list.
PostPosted: 00:43 - 28 Dec 2010    Post subject: Reply with quote
Obviously depends entirely on the bike Confused.
Ie, if it's just had a decent service that I trust and I got it for daily use, will just start riding it.
In other cases, the last bike I bought for myself went straight in to the lock up and hasn't been touched since.
CaNsA
PostPosted: 00:55 - 28 Dec 2010    Post subject: Reply with quote
I have a good look at it before i buy it,
bearings (headstock and wheel)
pads
chain
sprocket
tyres
suspension
etc etc etc
If i buy it i'll ride it for a week and listen to all the noises and stuff and goto my mates garage and tell him what im hearing etc etc
Might change the oil, might get new tyres but i doubt it like lol
Frost
PostPosted: 01:19 - 28 Dec 2010    Post subject: Reply with quote
I basically give it an MOT and pull off any stupid or broken bits. I usually clean up any nasty bits, check the levels of consumables etc. The bike will usually get an oil and filter change very early on unless i know for a fact it's been done already. If it's high mileage i might do the clutch too whilst the oils out. At some point in the first week of ownership i'll strip down and clean the brakes as i tend to be quite a hard braker and like to have some confidence in them.
Usually the bikes i buy have running problems which will require experimentation with spark plugs, batteries, carb setup. I think it's safe to say that after i've owned a bike for about a week it'll be in good enough condition to keep running for a damn long time Laughing
rob_scott92
PostPosted: 02:24 - 28 Dec 2010    Post subject: Reply with quote
For the wee Gs it was a case of take it home on a trailer, tinker for two or three months and then ride.
This then followed by regular electrical issues spread over about a year Laughing
The 350 was just a case of pass test and ride, then fall off and discover rear shocks were knackered Rolling Eyes
Although, 7 months later and nothing else has gone wrong apart from deeed battery Very Happy (tempting fate i know Shocked )
First bike: 1982 Suzuki Gs 125 'The beast MK1' Wink > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p
Dazbo666
PostPosted: 03:02 - 28 Dec 2010    Post subject: Reply with quote
I've only ever bought running bikes, so it's been a case of giving each one a change of oil, filter & plugs etc
Word of the day : DILLIGAF
hmmmnz
PostPosted: 06:20 - 28 Dec 2010    Post subject: Reply with quote
i always do oil,filters, plugs, valve clearances, grease all bearings, and generally change out the head race bearings.
the humans are dead
I kick arse for the lord
Glenben92
PostPosted: 07:39 - 28 Dec 2010    Post subject: Reply with quote
FULL service basically. Including the most thorough clean of it's life, and waterproofing all of the electrics with holts damp start.
new plugs
fresh synth oil
chain clean, lube, tension and wheel alignment
bleed brakes
check / set the brake light switches
check / set clutch cable / throttle cable
tyre pressures
oil throttle cable / choke cable / clutch cable
oil anything else that moves. steering / suspension / axles
Check for tax disc holder / tax disc, people love to leave you without 'em.
Join the owners forum.. usually comes in handy.
57 Huoniao HN125-8 - Smile, 97 Kawasaki GPZ500S - Very Happy
99 Yamaha FZS 600 - Wink
Mod 2 Passed - 01/10/2010
Chalky.
PostPosted: 10:38 - 28 Dec 2010    Post subject: Reply with quote
Within a week I usually drop it.
waffles
PostPosted: 11:04 - 28 Dec 2010    Post subject: Reply with quote
A service then sort out any tarty bits that may need doing. The TT had crappy paint on some of the metal bits so I took those off and got them powdercoated black which tidied it up lots. New footpegs to replace the mismatched set and new front indys. Then it got treated to a new db screen and a clean and polish including the insides of the fairings.
The xr is getting prepped for trail riding so im getting new grips (the ones on there are wearing out and ripped), handguards, spark plug and some tug straps to pull it out of anything I fall into. Other than that I am not going to bother too much as shiny new bits will get destroyed eventually.
My first two bikes I did nothing to other than check oil.
craigs23
Mr Muscle
PostPosted: 11:06 - 28 Dec 2010    Post subject: Reply with quote
Depends on the bike.
My latest purchase had had a full service including new pads, tyres, chain and sprocket, valve clearances.
But I still felt the need to clean it, as I probably do with all my bikes (even the brand new ones I think).
Along the way that allows me to spot any other work that might need doing that I haven't felt when riding, or to gauge a sort of history of the bike or what the previous owners had been like (a sort of archeology, based on a more detailed inspection, showing up previous hidden bodge jobs, bike cleanliness, wear and tear of certain parts, etc). The bikes tend to get a liberal coating of ACF50 or a lick of paint where needed here and there. Forms a nice basis for me to start on, be it a project or even to keep the bike maintained from a certain standard.
I also spend the time working out what modifications I would add myself. Recent alterations for my latest purchase has involved a tail tidy, fender extender, rear hugger, shock protector, etc.
A trip to an online owner's forum is usually made as well scouring the internet for an online manual or similar (although I tend to do that before I pick a new bike up).
PostPosted: 11:15 - 28 Dec 2010    Post subject: Reply with quote
That is all.
If it needs anything done to it you can usually tell on the first ride.
I picked my new bike up 70 miles away from home and rode it back. Everything seemed fine. In the new year I'll service her properly.
Digitalize
PostPosted: 16:36 - 28 Dec 2010    Post subject: Reply with quote
For my Hornet - Strip it down, realise I've taken a massive project on, worry a lot, not do much, and start to feel bad Embarassed
1998 CB600F Hornet
PostPosted: 16:56 - 28 Dec 2010    Post subject: Reply with quote
Nothing.
The Artist
PostPosted: 16:58 - 28 Dec 2010    Post subject: Reply with quote
Varies but on most bikes I ride them.
Gone
PostPosted: 17:03 - 28 Dec 2010    Post subject: Reply with quote
Kick tyres, fill tank, ride.
PostPosted: 17:04 - 28 Dec 2010    Post subject: Reply with quote
The Artist wrote:
Varies but on most bikes I break them.
Corrected Wink
Handsome
PostPosted: 17:06 - 28 Dec 2010    Post subject: Reply with quote
On my NSR I did nothing to it per-say apart from fix the thing every few weeks...
On my Zephyr I just stiffened the suspension up, oh and put a better rack on the back as I broke the home made one tightening bungie cords...
On my SV I had to unwind the rear shock and soften all the other suspension up as the bloke before me was a lanky bloke who used it as a trackday and weekend tool, this is going from the suspension set up and dyno print outs, and the tyres as the ones he had on were shit, gave me no confidence whatsoever, the Double Bubble, SV tank pad and SV rear hugger I've left on...
The last post was made 15 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.75 - MySQL Queries: 16 - Page Size: 136.51 Kb
