| Thom |
 Thom World Chat Champion
| Drongo |
 Drongo Derestricted Danger
| N cee thirty |
 N cee thirty Banned
| Thom |
 Posted: 23:53 - 13 Jan 2011 Post subject: |
How to fit the engine is going to depend on the particular engine. I presume that the engine would be a small diesel not designed for car or bike use, so it would need a gearbox. Should be possible to connect the engine and an old pre unit gearbox to get chain drive.
However the amount of work would probably count it out from being cheap.
| Shaft |
 Shaft World Chat Champion
 Posted: 00:10 - 14 Jan 2011 Post subject: |
Somewhere in the dark recesses of my mind, a small and feeble light bulb has just cast it's dim glow over a magazine picture of a Royal Enfield with a diesel engine, which gave spectacular fuel consumption, but in every other respect, was neither use nor ornament.............but perhaps I just imagined it.
Citroen/Peugeot did a rather neat, all alloy 1360 diesel, which was light, compact and reasonably powerful, but as Keith said, the gearbox could be a challenge.
Transverse would need a unitary gearbox, inline would be easier, but you would be looking at a bespoke frame design.
Unless you've got lots of time and money at your disposal, I'm not sure I see the point. ____________________ Things get better with age; I'm close to being magnificent........
 Posted: 00:34 - 14 Jan 2011 Post subject: |
Start with a shaft drive bike.
Otherwise you'll need a pre-unit, chain drive gearbox which are almost all off old brit bikes.
A BMW, Ural or Guzzi are good starting points. The what you need is a custom madecollar to join the engine to the original clutch/gearbox unit or to join the car engine clutch to the bike gearbox. I've seen this done several times.
Another alternative is to do away with the gearbox altogether and run a car clutch straight through to a shaft on a single gear. With a sufficiently big car engine, this will still do silly mph while being able to pull away. Saw this done with a pinto diesel.
Enfields lend themselves to diesel conversions because they have a seperate gearbox that bolts to the frame. That means you can fit any diesel engine which fits in the frame and attach it to the primary drive using a belt or chain. They usually use a generator engine which is why they are so slow (but will do over 200mpg!).
I've seen a peugeot diesel engine used to power a sidecar outfit via an Albion 4-speed gearbox before but the engine was mounted between the bike and sidecar to get the final drive alignment.
Doesn't have to be expensive, but you need to be good with your hands. This thread may be of interest (1.9l VW diesel in the process of being shoehorned into a Dnepr chassis):
https://www.network54.com/Forum/598839/message/1294268741/The+next+FrankenFail+bike. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Thom |
 Posted: 10:03 - 14 Jan 2011 Post subject: |
If you really want one then not sure when the military diesel bikes will start to be sold on.
There was also a bike made in France in the late 1980s which used car engines including a diesel. However not sure how many were made (or even if the whole operation was a scam for EEC funds), and I have not been able to find anything on them via Google.
| chris-red |
 Posted: 10:29 - 14 Jan 2011 Post subject: |
| Martay |
 Martay World Chat Champion
 Posted: 23:17 - 14 Jan 2011 Post subject: |
I think the Aixam car uses a 2cylinder diesel 500cc 'lump' and a form of Variator / belt drive. Is that too small? ____________________ Eat well, poo hard
Drives: Cavalier 2.0 16v
Rides: Slightly ratted Honda City Express  |
| yen_powell |
 Posted: 09:29 - 15 Jan 2011 Post subject: |
Enfield Robin was the diesel bike I remember. I have a vague recollection of a bike magazine saying you could ride from London to the scottish border and back without refueling.
https://www.dieselbike.net/Hamm09/FujiRobin.JPG ____________________ Blackmail is a nasty word........but not as nasty as phlegm!
XT1200Z and a DR350 in bits |
 Posted: 09:54 - 15 Jan 2011 Post subject: |
Aye. Robin Diesels have been used in a few bikes. They are a generator engine and the bikes are all dog-slow.
The MZ ones have a variometer gearbox like a twist and go.
I've also seen one done with hydraulic drive. The diesel engine powering up the hydraulics them the wheel powered by a hub-mounted hydraulic motor. I'm a bit pissed off about that one because I reckon the company that made it pulled the concept off a discussion I was having with some mates on the ratbike board a good three years before they built it. There were details we'd come up with (such as a pressure dump-valve operated by a clutch lever for stopping) that were included in the design. They didn't make it 2WD though, which is what I wanted.
Here's another coold diesel bike. Hand crank start.
https://www.ratbike.org/docs/55.php ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 15 years, 302 days ago. Instead of replying here, would creating a new thread be more useful? |
