| dextersaurus |
 dextersaurus World Chat Champion
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 17:29 - 29 Jan 2011 Post subject: |
https://image.made-in-china.com/2f0j00DevTnHuPaLkU/Rubber-Mallet.jpg
Or failing that a proper hammer and a bit of wood against the spindle.
Hit it you girl.
You can't "unscrew" it since it isn't threaded inside the wheel. A rubber mallet's always done the job for me. ____________________ My Flickr
| dextersaurus |
 Posted: 17:30 - 29 Jan 2011 Post subject: |
Just wanted to make sure there wasn't some wierd japanese way of doing it
Just smack it with a hammer then.... do-able
Dunc |
| Wafer_Thin_Ham |
 Posted: 17:33 - 29 Jan 2011 Post subject: |
Helps if you lift the weight of the wheel with one arm as you whack to take some weight off the spindle and it'll slide out more easily.
When other end is proud by a few inches (depending on the strength of your whack and how stiff it is) just pull it out with your hands (may need a jiggle at this stage).
Don't forget to grease it when you put it back in.  ____________________ My Flickr |
| dextersaurus |
 Posted: 18:20 - 29 Jan 2011 Post subject: |
I've had this before.
There will be a (surprisingly small) amount of corrosion on the spindle and a correspondingly small amount of corrosion on the inside of the alloy calliper hanger. This'll be where it's hanging up.
I'd apply some penetrating oil to this bit and try to tap the spindle or the hanger back and forth a bit.
Applying some heat directly to that casting would probably help matters a lot but be aware too much heat could damage the bearing seals. Freeze and release spray might help too.
I do recall I landed up clouting it out with a big hammer by putting the nut back on the spindle, resting a block of hardwood against it and giving it a few big hits with a lumphammer. Just be careful you don't damage the threads. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Casper |
 Casper World Chat Champion
 Posted: 18:33 - 29 Jan 2011 Post subject: |
Never buggered bearing yet using a hammer.
FFS Dunc, for once your bike looks cleaner than mine
How you doing mate? |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
 Posted: 21:15 - 29 Jan 2011 Post subject: |
| Kickstart wrote: |
The spindle has probably seized to the inside of the bearings or to the bearing spacer.
Belting it might help but it will be quite easy to trash the thread on the spindle (you can try putting the nut on but not all the way down, so you land up smacking the nut).
Wotcha.
This happened to the front wheel spindle on my trike last September. Despite using a gas torch, a six foot bar, a 28lb sledge hammer and some four foot Stilsons, the bugger would not shift. Plan "B" involved an hydraulic press - even this did not move it. In the end, I had to drop the fork links out, cut through the spindle, then machine it out, where it had siezed in one wheel bearing, and one spacer. The other three bearings were free, and the brake calliper was free.
Bottom line . . . . off the road for a month, and a bill for £140 to have a spindle made ( could have made it myself, but this injury means I can't stand and operate the lathe ).
Week 1
Week 2
Week 3
Week 4
Week 5
Let's hope penetrating oil and a big hammer do the trick  ____________________ Cheers.
L.W. - www.moonshiners.org.uk |
| Rogerborg |
 Rogerborg nimbA
| dextersaurus |
 Posted: 00:15 - 31 Jan 2011 Post subject: |
Ended up duct taping a bit of wood round the swingarm so it was up against the spindle and absolutely smacking it with a sledgehammer
Got it out eventually
No damage to the spindle, no damage to the (surprisingly good condition) bearings. it was seized to the spacers, managed to free it off with the hammer and turning it on the other side.
polished it up, and going to give it a decent coating of grease when it goes back in.
Wheel's away just now getting the tyre changed so that should be that
Got another problem now though, the sprocket carrier.
The bolts have been pressed down so they cover the bolts, can't get them off. is there a reason for this?
Cheers
Dunc |
| fiery tupp |
 fiery tupp Trackday Trickster
| dextersaurus |
| fiery tupp |
 Posted: 00:42 - 31 Jan 2011 Post subject: |
Do you mean, hammered over like a rivet ? if so you could file them flat maybe ?  ____________________ If you can't fix it with a hammer , use your head . |
| dextersaurus |
| fiery tupp |
 Posted: 00:56 - 31 Jan 2011 Post subject: |
I dont think that they should be like that , someone prob bashed them over as there are no locking tabs & will , i think have to come off & be replaced with new nuts & bolts , unless anyone knows different ?  ____________________ If you can't fix it with a hammer , use your head .
| Ichy |
 Ichy World Chat Champion
 Posted: 00:59 - 31 Jan 2011 Post subject: |
| dextersaurus |
 Posted: 01:15 - 31 Jan 2011 Post subject: |
Ahh, that's what it is!
Cheers!
Dunc |
The last post was made 15 years, 235 days ago. Instead of replying here, would creating a new thread be more useful? |
