Zinc coated or A2/A4 Steel nuts and bolts?
spetom
PostPosted: 10:20 - 07 Feb 2011    Post subject: Zinc coated or A2/A4 Steel nuts and bolts? Reply with quote
When replacing nuts and bolts on an engine, carb or all over the bike in general, is it better to use softer zinc coated bolts or harder A2 or A4 stainless steel?
PostPosted: 10:23 - 07 Feb 2011    Post subject: Reply with quote
Personally it would depend on the part. Safety critical items I would tend to stick with OE items. Non critical I would use stainless.
PostPosted: 10:29 - 07 Feb 2011    Post subject: Reply with quote
Most stainless is weaker and more brittle than mild steel. Certainly unless you are going to be paying a lot of money for it.
If it was something not seeing much load such as bolts holding on plastics or a side cover, I'd use stainless.
If it is something structural, I'd use mild steel bolts stamped with 8,8 on top unless the original was a higher grade.
For super high load things like brake calliper bolts, I'd use original parts.
spetom
PostPosted: 17:40 - 07 Feb 2011    Post subject: Reply with quote
Vincent wrote:
Be careful bolting S/S fasteners into ally too - they can seize big time.
This is what I thought. I'm afraid I can't find OEM parts I've used A2 stainless steel into the carbs and other parts of the engine when replacing crappy heads.
I was told that the stainless steel can dissolve other metals around it if they are not stainless?
PostPosted: 17:48 - 07 Feb 2011    Post subject: Reply with quote
It is difficult to know. Stainless steel can seize in place, but so can mild steel. Bigger problem is that stainless steel will likely be FAR harder to drill out than mild steel (from memory it work hardens with the heat from the drill). Pretty much any 2 dissimilar metals when put together will trigger corrosion.
I have used stainless steel bolts loads of times on things like carb float bowls and engine outer cases. But I do use copper slip (and you will also find things about copper causing corrosion but can't say I have ever had an issue with copper grease).
The last post was made 15 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 16 - Page Size: 51.14 Kb
