| Alex_ |
 Alex_ Two Stroke Sniffer
| hmmmnz |
 hmmmnz Super Spammer
| Alex_ |
 Posted: 14:08 - 07 Feb 2011 Post subject: |
Yes, that's pretty much it.
The switch is a simple, 2-position on-off switch where it says "combination switch". Make for on, break for off.
You might want to keep a neutral light? Hand for both knowing you're in neutral and for telling you the ignition is on.
I redid them a bit neater for you. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 Posted: 14:12 - 07 Feb 2011 Post subject: |
| hmmmnz wrote: | you dont need half that stuff,
no battery, no rectifier,
just the ignition coil in the stator(points part) the points
the coil, spark plug an a kill switch,
Nah, that one needs the battery. No internal connection from the stator to the points. The coil is powered up off the battery and breaks down via the points.
EDIT: Actually, that's not strictly true. The circuit will self-excite. The battery is there to act as a voltage regulator. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Alex_ |
 Posted: 14:54 - 07 Feb 2011 Post subject: |
thanks for that mate thats a bit easier to read lol, yeah i'd may as well add the light, could i use any light really?
thanks |
| Alex_ |
 Posted: 15:00 - 07 Feb 2011 Post subject: |
| Alex_ |
| Alex_ |
 Posted: 23:40 - 07 Feb 2011 Post subject: |
Ok. I think that's a pattern replacement one. Honda usually use orange for left hand flasher wiring.
It doesn't matter which way round the two "coil" wires are, it does matter which way round the live and earth are.
Red to battery positive, Green to earth (or battery negative), yellow to yellow, orange to pink.
On the subject of earths. Remember you need to have the battery negative connected to a metal part of the engine or you'll get no spark. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Alex_ |
 Posted: 00:06 - 08 Feb 2011 Post subject: |
Yeah mate ive got a temporary earth for testing on the battery -
Hopefully I'll get the coil tomorrow and be able to get started with things
Thanks for all the help  |
| tahrey |
 tahrey World Chat Champion
| Alex_ |
| tahrey |
 Posted: 22:03 - 09 Feb 2011 Post subject: |
DO NOT earth the white wire on the generator!
They aren't designed to run a headlight off the battery. That wire is for running the lights.
If you want a lighting system, you hook it up to the white wire on the alternator, it runs directly off that and only when the engine is running (A.C. power). You will need a total draw of no less than 29W hooked into that wire or it'll pop the bulbs. Much more than that and they'll be dim. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Alex_ |
| Alex_ |
 Posted: 01:51 - 10 Feb 2011 Post subject: |
| Alex_ wrote: | ok hopefully havent caused any damage, so engine needs earthed, battery negative,does the coil need earthed also?? if so, do i bolt it to metal or run a wire from it?any more
hopefully ive missed something as ive tried more or less everything here, i have a multimeter if i need to do any checks
thanks |
If it wasn't running, I doubt it would have generated enough power to damage anything. If the engine had fired up, you'd have been in trouble though.
The coil earths via the points which is what makes the spark. No seperate earth needed (or wanted).
If you've been getting a spark, it's broadly working, can't be far off. Having that white wire earthed wont have been helping matters.
I'd probably try it without the bulb in your neutral light for the time being, just in case that's causing your problem.
If it's an engine that's sat a while, it'd be worth giving the contact surfaces on the points a clean up with some emery paper (or a points file) and resetting the gap. You can set the timing later once it's producing a good spark.
Another thing to try. Turn the engine so the points are closed, turn the ignition on and seperate the points with something insulated (bit of plastic or wood). If a spark jumps the gap, there's a good chance you have a duff condenser. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Alex_ |
| Alex_ |
The last post was made 15 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
