RS125 idling
Formerly known as
P.
PostPosted: 17:14 - 11 Feb 2011    Post subject: RS125 idling Reply with quote
The idle screw seems to do absolutely shit all.
Just spins round and round...no change in revs... really pisses me off!
Any idea what to do, at the moment ive adjusted it throttle end.
gmanxiii
PostPosted: 17:19 - 11 Feb 2011    Post subject: Reply with quote
The plastic knob on my last two bikes tended to slide down the screw itself so wont actually grip and adjust anything unless you pull it towards you and turn it. Maybe try that?
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
Formerly known as
P.
PostPosted: 21:31 - 11 Feb 2011    Post subject: Reply with quote
ok, that didnt work, ive adjusted throttle end, got 1400-1500 on the warm tickover now.
Not 100% on this....so how do I sort it Laughing
skatefreak
PostPosted: 09:37 - 12 Feb 2011    Post subject: Reply with quote
This is the idle screw as in you can see the needle itself is turning and moving in/out yes?
If so, turn it all the way in counting the turns, bring it all the way out and have a gander to see if its all there (a missing tip could cause this) then put it back in and turn out the number of turns counted previously.
Or maybe the idle channel in the carb is blocked...
Best regards
-Jvr
Formerly known as
P.
PostPosted: 10:28 - 13 Feb 2011    Post subject: Reply with quote
Best regards
-Jvr
Ive gone over it...seems to work fine.. just doesnt affect the idle. Good thing is ive got it choking at 2500k and it idles smooth off choke at 1450-1500 I can live with that for now! Laughing
PostPosted: 11:42 - 13 Feb 2011    Post subject: Reply with quote
Holding the idle up on the throttle cable isn't a good idea because the revs will rise when you turn the steering to lock.
I'm about today if you fancy a ride over. Got some machining work to do but I can spare a bit of time.
The last post was made 15 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.32 - MySQL Queries: 16 - Page Size: 49.81 Kb
