motorcycle lift/table
flumpy7
PostPosted: 00:08 - 15 Feb 2011    Post subject: motorcycle lift/table Reply with quote
Hi guys
Anybody know of a good, reasonably priced motorcycle lift/table. Ideally i need one that enables access/clearance to the front and rear wheels and is able to be moved with the bike on.
2012 Sinnis apache
PostPosted: 00:25 - 15 Feb 2011    Post subject: Re: motorcycle lift/table Reply with quote
I've often been tempted by this:
https://www.on-bike.com/products_original_red.htm
Not THAT cheap, but not too bad considering other stuff out there.
Ed Case
PostPosted: 11:07 - 15 Feb 2011    Post subject: Re: motorcycle lift/table Reply with quote
flumpy7 wrote:
Hi guys
Check out SAL Easylifts www.easylifts.com or 01697349295.
I bought the smaller of the two they do £290 delivered, handled my Laverda triple easy and that weighed well over 500lb. I've seen nowhere else any cheaper.
PostPosted: 12:41 - 15 Feb 2011    Post subject: Reply with quote
How about an engine hoist? You can get a wheeled 1 ton hoist for about £125 delivered. I haven't used one on a bike though, so I don't know if the weight distribution will be a problem compared to lifting an engine.
Chalky.
PostPosted: 12:48 - 15 Feb 2011    Post subject: Reply with quote
Would they be hard to make?
PostPosted: 13:37 - 15 Feb 2011    Post subject: Reply with quote
Pretty sure there's free plans out there to make bike tables, including hydraulic ones. However, if you have to buy the metal in, etc - I can see it ending up being a similar price.
flumpy7
PostPosted: 17:00 - 15 Feb 2011    Post subject: Reply with quote
Thanks guys
G, that lift looks tempting but what about oil draining and stuff how do you get to the bottom of the engine?
2012 Sinnis apache
Dagon
PostPosted: 13:32 - 16 Feb 2011    Post subject: Reply with quote
That looks alright. Been half thinking of a lift of some sort for a while but space is an issue and that look nice and compact.
PostPosted: 13:37 - 16 Feb 2011    Post subject: Reply with quote
Depends on the engine re oil draining I expect - but I'd have thought it'd be fine with the wheel hoops. Most engines tend to have their drain plug a little off set anyway.
tbad93
PostPosted: 13:53 - 16 Feb 2011    Post subject: Re: motorcycle lift/table Reply with quote
flumpy7 wrote:
Hi guys
use a wooden log thats why i used to get my bike off the ground and it worked perfectly i balanced it on the belly panel and it dunt move one bit at all, stayed there foa month while i did the bike up
T:BAD Razz
The last post was made 15 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.93 - MySQL Queries: 16 - Page Size: 65.05 Kb
