| curryhead |
 curryhead Nitrous Nuisance
| Joe Camel |
 Joe Camel Nova Slayer
 Posted: 16:35 - 19 Aug 2002 Post subject: |
Rejetting is not ALWAYS needed, see how it runs first...
for example, if it runs OK high up the revs but crap low down, then you need to add more fuel in the midrange, try dropping the needle one notch at a time and see if it improves. Conversely, if it is OK low down but runs out of puff high up the rev range, lift the needle ONE NOTCH AT A TIME. this can make a massive difference.
If you do put a bigger main jet in beware of overfueling, this will give you lots of "bogging down" as you open the throttle.
Also with a bigger jet there will be less vacumn to lift fuel. slow throttle response is often a symptom of this, try the pipe, with a good filter, ie K&N or powerflo, befroe messing with carb.
This will end in tears without the proper test equipment,
good luck. ____________________ ***THE VOICES MADE ME DO IT***
***NOT STOCK & TWO SMOKIN BARRELS*** |
| Hunter |
 Hunter Nitrous Nuisance
 Posted: 18:25 - 19 Aug 2002 Post subject: |
You maybe able to get away with messing about float levels and needles in the carb. A plug chop should tell you what exactly is going on inside the engine when you put a new pipe on.
| Kickstart |
 Kickstart The Oracle
| Ropehead |
 Ropehead Could Be A Chat Bot
| curryhead |
| Ropehead |
 Posted: 13:42 - 20 Aug 2002 Post subject: |
PLUG CHOPP>
drive along keeping the engine at about 8,000 then press the KILL swich pull the cluch in and roll to a stop, remove the plug and check to see what its like,,, it should be coffee brown ,,, lighter. to hot needs bigger jet... oily brown needs smaller jet..
EASY  |
| curryhead |
The last post was made 23 years, 348 days ago. Instead of replying here, would creating a new thread be more useful? |
