Author |
DarylInAjax |
![](images/spacer.gif) DarylInAjax L Plate Warrior
Joined: 21 Mar 2011 Karma : ![Good Karma (Level 1)](/images/karma/green_9.gif) ![Good Karma (Level 1)](/images/karma/green_3.gif)
Back to top |
You must be logged in to rate posts![](images/spacer.gif) |
![](templates/standard/images/spacer.gif) |
prawny1 |
![](images/spacer.gif) prawny1 World Chat Champion
![](images/avatars/11634459184a2434efb0d6e.jpg)
Joined: 28 Jun 2005 Karma : ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_9.gif) ![Excellent Karma (Level 3)](/images/karma/gold_1.gif)
Back to top |
Robby |
![](images/spacer.gif) Robby Dirty Old Man
![](images/avatars/5106db863f1f21bddb59d.jpg)
Joined: 16 May 2002 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_8.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 09:33 - 24 Mar 2011 Post subject: |
Balancing shouldn't cause this much trouble, it can give a rough tickover but would rarely be this big a problem.
The point about stuff getting past the fuel filter is good too, a surprising amount will get through it. The only advantage here is that a paper element will get stained quickly, showing you that there's a lot of crap going through. Doesn't stop you needing to clean the carbs, but does help trace the fault.
If there is any rust in the tank, then it needs treating. Phosphoric acid is your friend, I've used it on a couple of really seriously rusted tanks and ended up with perfectly clean, slightly pitted metal. It eats rubber and doesn't appear to be great friends with aluminium (I used a gallon of the strongest I could buy on ebay, topped up with an equal amount of boiling water from several kettles) so bear that in mind.
I'm siding with a clean-workbench carb strip, including a good inspection of rubbers. You could try spraying WD40 on the rubbers with a running engine first to check for an air leak, but this isn't a 100% accurate test. |
Back to top |
MarJay |
![](images/spacer.gif) MarJay But it's British!
![](images/avatars/19046982246598b4e87cf3.jpg)
Joined: 15 Sep 2003 Karma : ![Excellent Karma (Level 4)](/images/karma/gold_9.gif) ![Excellent Karma (Level 4)](/images/karma/gold_9.gif) ![Excellent Karma (Level 4)](/images/karma/gold_9.gif) ![Excellent Karma (Level 4)](/images/karma/gold_9.gif) ![Excellent Karma (Level 4)](/images/karma/gold_4.gif)
Back to top |
G |
![](images/spacer.gif) G The Voice of Reason
Joined: 02 Feb 2002 Karma : ![Outstanding Karma (Capped)](/images/karma/capped_9.gif) ![Outstanding Karma (Capped)](/images/karma/capped_9.gif) ![Outstanding Karma (Capped)](/images/karma/capped_9.gif) ![Outstanding Karma (Capped)](/images/karma/capped_9.gif) ![Outstanding Karma (Capped)](/images/karma/capped_9.gif)
Back to top |
MarJay |
Back to top |
![](/images/spider_left.gif) |
The last post was made 13 years, 82 days ago. Instead of replying here, would creating a new thread be more useful? |
![](/images/spider_right.gif) |
