| dna50 |
 dna50 Renault 5 Driver
| c clarke |
 c clarke Borekit Bruiser
 Posted: 01:17 - 26 Mar 2011 Post subject: |
okay mate i did this a few months ago but on a ped, but i guess its the same steps
basically take the starter motor side off so you can see the belt ect
then you will need an air gun or some special tools to knock the variator nut off. you need an air tool because the variator spins with the nut.
once you have done that take the variator off and drop the rollers out and put the knew ones in, job done.
with the belt i think its a bit different to when i did mine, so i wont say anything to confuse you, just goolgle it or something its simple so you should be able to work it out yourself
make sure you remember how it goes back together hope that helps. ____________________ cclarke |
| Nope. |
 Nope. World Chat Champion
 Posted: 02:08 - 26 Mar 2011 Post subject: |
Right, to do the rollers you first remove the transmission case (the bit with the kick start lever on it) Then you use an impact wrench to remove the nut, you have to use an impact wrench as if you try to use a socket it will just turn the variator and when your doing it up again if you dont tourque it enough it will just fly off messing up your transmission. Once youve taken the nut off you need to carefully remove the variator, I say carefully because there is a spring behind it called the contra and it will shoot off or even fling the variator into your face if your not careful.
Once you have the variator off you need to unbolt the back, remove the rollers and fit the new ones. If you get the rollers wrong you will either loose top end or loose acceleration and the bike will be revving its nuts off so make sure you know what your doing. Once you have the new rollers in you need to do the back of the variator up again and put it back on the shaft with the contra behind it. FINGER TIGHTEN THE NUT FIRST so as not to cross thread the crank (Very bad!) and then use the impact driver to do it up again but make sure its not too tight as again, you will damage the crank.
Once its done you can put the case back together and take it for a ride.
Changing the belt is very easy and this video should explain it pretty well:
https://www.youtube.com/watch?v=fBHAM1am-UE
If you don't feel confident doing it yourself I suggest you take it to a garage and ask to watch them so you know what to do next time. Better spend a bit more money then ruin your bike and end up spending an absolute fortune on repairs. ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
Current: 2011 Yamaha XT660Z Ténéré, 2003 Yamaha YZR-R1 5PW (In Build), 2009 Kawasaki ZZR1400 |
| prawny1 |
 prawny1 World Chat Champion
| dna50 |
The last post was made 15 years, 222 days ago. Instead of replying here, would creating a new thread be more useful? |
