Metal fillers?
pepperami
PostPosted: 19:02 - 08 Apr 2011    Post subject: Metal fillers? Reply with quote
So can anybody tell me if any of the mixable metals/fillers are petrol resistant, and would they be suitable for plugging a tiny hole on an ally carb body?.
Yes I`m going to be careful and the hole is not near any of the jets
Can anybody give me a brand that is good
Thank in advance Thumbs Up
stirlinggaz
PostPosted: 19:11 - 08 Apr 2011    Post subject: Reply with quote
i've used araldite metal putty on a carb before & it lasted fine.
cheers,
GAZ
pepperami
PostPosted: 19:23 - 08 Apr 2011    Post subject: Reply with quote
Areldite metal putty? ok thanks for that, I did`nt know they did a metal putty.
I tried ordinary Areldite this afternoon and it was FAIL Sad .
I`m going shopping tomorrow so I`ll look out for that Thumbs Up
DrDonnyBrago
PostPosted: 19:49 - 08 Apr 2011    Post subject: Reply with quote
The yanks use JB weld for carb bodies, I have used plastic padding leak fix on an oil sump and it worked (is still working 3 years on) well. Halfords sell a steel epoxy putty which i believe says it is suitable for petrol tanks.
You might have more luck getting it welded up though.
Gazdaman
I did a trackday!!!
PostPosted: 19:50 - 08 Apr 2011    Post subject: Reply with quote
I've had good results with 'chemical metal' before. Obviously take the part off, and clean it and allow the filler to 'go off' before you expose it to petrol etc.
Give it the best chance to work etc.
Gaz
PostPosted: 11:15 - 09 Apr 2011    Post subject: Reply with quote
JB weld is teh seks if you can get hold of it.
Otherwise, the sediment bowl on the fuel tap on my CB125 consisted of about 70% araldite chemical metal and 30% the original alloy for the two years I had it.
Now, next question. How the hell did you manage to make a hole in your carburettor?
PostPosted: 11:18 - 09 Apr 2011    Post subject: Reply with quote
Drill & pop rivet.
tsmith
PostPosted: 11:32 - 09 Apr 2011    Post subject: Reply with quote
jb weld. i bought mine off ebay
The Artist
PostPosted: 11:51 - 09 Apr 2011    Post subject: Reply with quote
+1
pepperami
PostPosted: 20:24 - 10 Apr 2011    Post subject: Reply with quote
[quote="stinkwheel] How the hell did you manage to make a hole in your carburettor?[/quote]
No I did`nt make a hole in the carb, I found a hole in the carb body.
It was very tiny and in the bottom of the float bowl ?
Anyway I bought a tube of "plastic Padding" chemical metal, and after cleaning and drying, it was applied.
well so far so good Thumbs Up
The Artist
PostPosted: 20:25 - 10 Apr 2011    Post subject: Reply with quote
Lol, you do you mean the drain screw hole?
pepperami
PostPosted: 20:47 - 10 Apr 2011    Post subject: Reply with quote
Er no! that`s got a screw in it Thumbs Up
The Artist
PostPosted: 20:55 - 10 Apr 2011    Post subject: Reply with quote
I mean opposite it, where petrol comes out when you unscrew it.
pepperami
PostPosted: 21:00 - 10 Apr 2011    Post subject: Reply with quote
Smile no it was just a small hole in the float bowl body ...... problem solved Thumbs Up
The last post was made 14 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.36 Sec - Server Load: 1.09 - MySQL Queries: 16 - Page Size: 83.21 Kb
