| Wyldkat |
 Wyldkat Nitrous Nuisance
 Posted: 18:42 - 12 May 2011 Post subject: Optimiser to Battery Connection?? |
Will this work?
I have just obtained a 6v optimiser so I don't have to keep removing the battery.
As you can (hopefully) tell by the picture-
*the connection from Battery to the Rectifier has been 'bodged' with a Terminal block (or choc block connector) this means the wires are weak and keep breaking;
*The Optimiser has Ring terminals to connect to Battery;
*I know the NEG(-) end will go onto the 'Earthed' connection onto the frame,
*I have been told to chop the POS(+) ring end off and feed the wire into the Choc Block (this would mean that the wires for Battery/Rectifier/Optimiser would all be connected)
Does this mean then that I can simply attach the Ring terminal to the Rectifier instead of cutting it up?
[/img][/list] |
| Nexus Icon |
 Nexus Icon World Chat Champion
| finpos |
 finpos World Chat Champion
| Nexus Icon |
| truslack |
 truslack World Chat Champion
| Wyldkat |
| stinkwheel |
 Posted: 10:40 - 13 May 2011 Post subject: |
What I would do is take the chocolate block connector OFF before it fails.
I would then replace it with either a double bullet connector attached to the rectifier (my preferance, these come with an insulating sleeve that goes over the top of them to prevent them shorting against the frame):
https://www.polevolt.co.uk/acatalog/1083-195.jpg
Or a piggy-back spade connector (harder to insulate these properly):
https://www.kitcarconsumables.co.uk/images/Red%20Piggy%20BAck%20Terminal.jpg
Then connect both the battery and the optimiser wires into it using the appropriate terminals.
If they are reasonably thin wires, you could also twist the optimiser +ve and rectifier wires together and crimp them both into the same terminal.
Do not attach the positive to the post on the rectifier, or anything that is in contact with the frame. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Wyldkat |
The last post was made 15 years, 170 days ago. Instead of replying here, would creating a new thread be more useful? |
