| Peter |
 Peter Derestricted Danger
| Paxovasa |
 Paxovasa World Chat Champion
| Peter |
 Posted: 13:23 - 12 May 2011 Post subject: |
I was told that in Mod 1 when you do the slow speed ride you no longer follow the instructor, he will stand behind you and watch,
And Mod 2 you are given several instructions in one go rather than the instructor firing them at you one at a time.
These if true are nothing to worry about as your still doing the same actions you would normally do but i was wondering if there was any others.
Amazing that when your coming up to a test you take every little bit of information in and over analyse it  |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:35 - 12 May 2011 Post subject: |
Mod 2 now has the 10 minute "independent riding" section where you'll be asked to ride towards a destination without receiving instructions. It doesn't matter where you go, just ride sensibly as you get there.
From 16th of May, Mod 1 has some small but significant changes for the better:
All the slow speed stuff is done first.
The slow speed ride is observed - you don't follow the examiner any more.
The exit from the fast bend is wider so you can pick a better line to the swerve test.
You get a "practice" go through the fast circuit and emergency stop speed trap. You won't be told your speed unless you ask, or unless it's excessive.
The emergency stop comes before the (more hazardous) swerve. If you fail the stop, the test ends without giving you a chance to bin it in the swerve.
The swerve stop zone is more generous now - it's no longer effectively a 2nd emergency stop.
If you don't make the minimum speed in the stop or swerve, you get your 2nd try immediately, not at the end of the test.
The minimum required speed for the emergency stop and swerve is now 48kph. If you only manage 48 or 49kph then that's recorded as a fault - you're allowed 5 in total - but you don't automatically fail.
The only thing to note is that there is now more manoeuvring between the exercises, so take observations. Other than that, it's all good, and a shocking attack of common sense by the DSA.  ____________________ Biking is 1/20th as dangerous as horse riding.
| gdog74 |
 gdog74 Two Stroke Sniffer
| gdog74 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:54 - 12 May 2011 Post subject: |
Oh, and the DfT still say that they intend to tell Jean-Claude Brusselsfellow to stuff his 50 "kilometrons per metric hour" speed limit and get back to a single test on the Queen's Highway using Imperial Miles Per Greenwich Hour, but there's no fixed timescale or details on that, so don't hang around waiting for it. ____________________ Biking is 1/20th as dangerous as horse riding.
| Peter |
| Codemonkey |
 Codemonkey Crazy Courier
| Peter |
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:09 - 12 May 2011 Post subject: |
Yup, the independent riding section is instead of rather than in addition to 10 minutes of turn-by-turn instructions, so the test isn't any longer. Do not worry about getting lost - it's not test of navigation, it's just to see that you can make safe, sensible decisions without being nannied.
That's a great point about all the stopping and starting in Mod 2. Plenty of opportunities to miss observations or forget to make or cancel a signal. Just take a deep breath before setting off each time; every second you spend taking observations is a second less where you could be racking up faults. ____________________ Biking is 1/20th as dangerous as horse riding.
| Moxey |
 Moxey World Chat Champion
 Posted: 16:12 - 12 May 2011 Post subject: |
Just had my test the other day at 8:15 and got to say that I preferred it honestly even if there is more traffic and congestion spent at least 20 or so minutes sitting in traffic.
My test was about 45-50 mins with 15 of it self riding which is not complicated at all; the examiner just tells you to pull over at a suitable location then gives you a destination he/she wants you to go to. Doesnt matter if you get lost as long as you do everything safely with correct observations then it's fine hell I ended up going completely the opposite direction to where they asked me to go! (accidentally ofc ) ____________________ Current: 02 FZS 1000 & 91 Royal Enfield Bullet 350 Some Bike Pics...
'I was too busy paying attention to pay attention' |
| MikeyBrown |
 MikeyBrown Scooby Slapper
 Posted: 10:30 - 13 May 2011 Post subject: |
| Peter wrote: | I was told that in Mod 1 when you do the slow speed ride you no longer follow the instructor, he will stand behind you and watch, |
I would find this one worse :/ after doing my mod1, I was glad that the instructor was in front of me, as it relaxed me a little as they can't watch what you are doing 100% of the time, as you're doing the manouvure behind them.
But hey, don't let these changes get to you. The test wont be that much different, and if you practice for the adapted manouvures, then you'll do fine
Good luck  ____________________ Past Bikes: '97 CG125, '91 GPZ500S, '01 FZS600, '07 S/Triple, '99 ZX9R, '82 GP125, '83 GP100, '03 SV1000S, '98 ZX6R
Current Bike: '07 FZ1N
Trackdays: Darley Moor - 15/6/12, Donington - 28/8/12 |
| N cee thirty |
 N cee thirty Banned
| MikeyBrown |
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:57 - 13 May 2011 Post subject: |
The problem they had was consistency of speed, and some examiners who started off quick then slowed down as you got closer, the infamous rogues.  ____________________ Biking is 1/20th as dangerous as horse riding.
| Killer Rat |
 Killer Rat Trackday Trickster
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:15 - 13 May 2011 Post subject: |
You're fine, there's no measured or maximum speed. The test is designed to see how you'd do in slow moving traffic, so you're fine to do a normal start (try not to pop a wheelie though) and then slow down to "walking pace".
Always bear in mind, the examiners are bikers too and want to pass you. ____________________ Biking is 1/20th as dangerous as horse riding.
| mjn51 |
 mjn51 Traffic Copper
| blurredman |
 Posted: 13:10 - 13 May 2011 Post subject: |
It's not bad following the instructor, it's completely and almost utterly flat ground. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 - 40k, 1989 MZ ETZ251 - 52k. |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:13 - 13 May 2011 Post subject: |
Yes, the new version starts next Monday the 16th.
| Blurredman wrote: | It's not bad following the instructor, it's completely and almost utterly flat ground. |
Indeed, but as I mentioned, they've had issues with examiners striding off quickly to get some distance, then candidates rush to catch up with them just as the examiner slows down, and it all ends in tears - well, wobbles, feet down and fails, then tears.
It's easily enough avoided if you've been warned to take your time starting off, but simply changing "follow me" to "show me" solves it nicely. It really does look like they've listened and made some sensible changes. ____________________ Biking is 1/20th as dangerous as horse riding.
| kramdra |
 kramdra World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 11:40 - 16 May 2011 Post subject: |
Mmm, that's a bit harsh, especially as it's subjective - you think we could stretch to a tin of paint to put some lines down.
On the other hand, who cares, a pass is a pass. Minors count for nothing.
If it bothers you, the DSA's complaints procedure is here. If nobody tells them that there's a problem with the test, or at that centre, or with that examiner, then they won't know and can't improve it. ____________________ Biking is 1/20th as dangerous as horse riding.
| Peter |
| kramdra |
The last post was made 15 years, 176 days ago. Instead of replying here, would creating a new thread be more useful? |
