Front end handling weirdness
PostPosted: 17:15 - 14 May 2011    Post subject: Front end handling weirdness Reply with quote
Right in france on mobile, what would cause a bike to feel like the front tyre has low pressure, the pressure is fine but the handling is heavy at low speed and generally just feels vague. Can people karma good answers my phone is abit limited. Ta chris.
jimbothe
PostPosted: 17:18 - 14 May 2011    Post subject: Reply with quote
Worn headstock bearings.
Binding front brake.
Broken spring internal.
Those are the three that come to mind.
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
PostPosted: 17:23 - 14 May 2011    Post subject: Reply with quote
Bike is a triumph thunderbird 900 btw.
PostPosted: 17:25 - 14 May 2011    Post subject: Re: Front end handling weirdness Reply with quote
Too much weight on the rear would be my guess.
Can you up the rear preload?
My KTM suffered from this horribly thanks to putting too much weight far too far back.
I had on my list to adjust the preload before I went (have to be careful on the 690, really need to have the rear spring compressed if possible) but didn't have time.
Handled fine with nothing on the back, but really horribly and wobbly with it. Was actually quite glad for the alps because it kept my speed down a bit. A few 'concerning' moments in the steep hills in Monaco rush hour.
PostPosted: 17:34 - 14 May 2011    Post subject: Reply with quote
This was unloaded, it may be worth upping the preload anyway, also when loaded apparently it vibrates more at speed but unloaded it was fine however 2 different riders opinions. Headstock bearings I would have thought it would 'crack' under breaking.
PostPosted: 17:39 - 14 May 2011    Post subject: Reply with quote
Also I would have thought broken spring internals would have made abit of noise and you could feel crunching. I will check the brake, but we were comparing disk and tire temps after a mountain run(don't ask) and the disk wasn't that hot.
PostPosted: 19:18 - 14 May 2011    Post subject: Reply with quote
I have heard of some handling issues being at the "wrong" end. So, if it feels like there is a problem at the front, its not entirely unreasonable to suggest that something might have gone at the back.
Does the front wheel turn freely? The other option is that the front wheel bearing has collapsed.
evoboy
PostPosted: 20:43 - 14 May 2011    Post subject: Reply with quote
This.
APT Motorcycles
Ingah
PostPosted: 17:15 - 16 May 2011    Post subject: Reply with quote
I'm thinking bearings too.
Both wheel and head bearings can easily be checked at the roadside.
-- Ingah
PostPosted: 17:23 - 16 May 2011    Post subject: Reply with quote
I would have checked the tyre (both pressure and odd wear pattern), then bearings. Head bearings if a bit tight can cause odd problems (you seem to land up constantly over correcting).
Is this a new or old Thunderbird? If the older one then it is like Charlottes, and the brakes stick rapidly (they are also very easy to strip and rebuild).
PostPosted: 17:41 - 16 May 2011    Post subject: Reply with quote
Binding brake would cause that, or as said a problem at the back end.
To check the brakes, go for a short ride without touching the front brake. Come to a stop using the back brake then flick a ball of spit at the front discs. If they're hot, there's your problem.
A soft back tyre will play havoc with the handling.
The last post was made 15 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 16 - Page Size: 72.88 Kb
